2005 5.4L Engine problems at Ford - Ford Truck Enthusiasts Forums
Old 11-17-2004, 11:26 AM
ExpyBob ExpyBob is offline
ExpyBob is starting off with a positive reputation.
I also added this to a thread about production delays but thought it would be worth while making it a seperate thread which might attract attention.
Ford Orders Stop Shipment Of 2005 Trucks, Mustang Due To Defective Engines -
Ford GT "40" Alleged To Have Defective Cylinder Heads
07 September 2004
Dearborn, Michigan.
Robert Lane
updated 27 September 2004, 3:35pm, est.
Internal Ford Motor Company documents supplied to BlueOvalNews substantiate the article below. We will post scanned copies of these documents on this site in the near future. Until then, let the uninformed take delivery of early model year production vehicles.
updated 08 September 2004, 10:00pm, est.
We are now stating for a FACTUAL matter that Ford has ordered assembly plants to stop shipping 2005 model year vehicles due to defective 4.6L and 5.4L engines. Should Ford wish to challenge this information, they know our address.
At this time, we are only ALLEGING that the GT "40" heads are defective.
The article below is presented how it was originally published.
Sources at one of Ford's engine plants told BlueOvalNews that Ford Motor Company has instructed assembly plants to stop shipping certain 2005 model year vehicles because they can contain defective 4.6L or 5.4L engines. BlueOvalNews was first altered to the problem after we received a news tip at the end of August.
The products that can contain the defective engines include the 2005 Ford Mustang GT, 2005 F-Series, 2005 F-Series Super Duty, Ford Expedition and Lincoln Navigator. Ford has instructed the assembly plants to stop shipping vehicles until they are screened to see if they contain the defective engines. It is not known if any products were shipped to consumers before the problem was noticed.
The 2005 model year 4.6L and 5.4L engines in question were built with defective cylinder heads. According to sources, the defective cylinder heads will have an adverse effect on performance and will cause the engine to fail to meet Ford's specifications. .
It's not immediately clear if Ford will replace the entire engine at the assembly plant or just replace the defective cylinder heads and approve the vehicle for shipment to customers.
A Team Mustang source told BlueOvalNews that a stop shipment order means that Ford won't ship GT Mustangs to dealers, but it doesn't mean that Ford will stop building Mustangs - they can still build V6 powered models until problems with the 4.6L engines are corrected. Further, even though Ford officially launched JOB1 of the Mustang today, shipments don't occur immediately. "Somewhere within two weeks after Job #1 we have an OK to ship meeting where all the upper management on the program proclaim the vehicle is OK to ship. . . .launching a new vehicle in a new plant can have its issues. That's just part of what a launch is all about.", said our source.
In what could prove to be the most devesting news; however, is that the Ford GT "40" is alleged to have cylinder heads that contain defects in the combustion chamber pocket area. According to sources, Ford is allegedly making design changes to the cylinder head and will create a new casting which is targeted for release by 01 January 2005. Rather than issue a recall for the Ford GT, Ford would most likely issue a TSB (technical service bulletin) and repair the vehicles only as needed. Look for an update on the GT heads at a later date.
Here we go again. Bob
Old 11-17-2004, 12:00 PM
150ford 150ford is offline
150ford is gaining momentum as a positive member of FTE.150ford is gaining momentum as a positive member of FTE.
I thought that was old news. I presumed they have the problem fixed. Does anybody have the latest update on the story.
Old 11-17-2004, 12:11 PM
Yes it's 7 weeks old.
But did you read near the end when it says---
"Ford would most likely issue a TSB (technical service bulletin) and repair the vehicles only as needed."
In other words send it out and if they complain we'll fix it otherwise tough luck.
Currently my 2004 Expy is in the shop having a ring and pinion gears replaced. Again, if I didn't complain they would have never said anything even though the ones in there are out of tolerance (or something). This is a common problem with 03 and early 04 Expy's.
The same way they quietly changed the amount of spark plug threads in the 03 and 04 engines.
There's a bunch of 97-2002's out there with the old design just waiting to pop out but Ford is gambling on it happening after warranty expiration.
Knowing this would I buy a truck with the new engine??? No way!
Just like I avoided buy an 03 Expy which was chuck full of problems. Even my 04 isn't as problem free as my 2000 was. I'm starting to miss it.
Just wonderful----Bob
Old 11-17-2004, 12:17 PM
I am glad I have the internet. Ill be more informed. Thanks for the info. Sorry about your troubles. A friend of mune just bought an 2004 expy with 12,000 miles. Says its been a great vehicle so far. I am afraid all automakers are guilty off this practice not just Ford. Unfortunate but true.Good Luck.
2004 Ranger, 2005-2006 Ford GT & 2005-2007 Mustang Airbag Recall edtahaney Ranger & B-Series 0 10-22-2014 04:08 PM
2003 - 2007 Ford Pickup Truck Vacuum Pump Electric for Models with V8 6.0L Diesel 1ATony Vendor Specials, Discounts, Product Announcements & Group Buys 4 01-31-2014 11:08 AM
2006 - 2008 Ford F150 Truck Wheel Bearing & Hub Assembly MOTORCRAFT 1ATony Vendor Specials, Discounts, Product Announcements & Group Buys 0 02-18-2011 01:36 PM
Tags
08, 2005, 20052006, 2006, 54, 54engine, 54l, bullitens, engine, f150, ford, problems, recalls, trucks, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
