TOW/HAUL- any way to set as start up default???
#47
#48
#49
Originally Posted by dapgar
this might sound really stupid, but i'm not trying to be a smarta$$. why can you just push the button tow/haul mode on the shifter, after you start the truck?
instead of going through the trouble of doing the mod. just a thought
Cause my CRS kicks in and I forget to engage Tow/Haul?
I just figure that somebody has gone to the trouble of designing a modification that will take a 12v input off of one of the upfitter switches and automatically throw the truck into tow/haul if the switch is on.
Why not take it a step further since the tow command system is smart enough to figure out that you have a trailer attached and find that 12 volt source in the tow command circuits and use it instead of wasting an upfitter switch?
#50
#52
First, 2002 trucks do not have a tow/haul at all. The do have an overdrive off button, so that's what I assume you mean. There's no relay in that circuit, so that's probably not the problem.
Take the plastic cover off of the steering column. The screws are on the bottom. Look at the wires that enter the shifter. One or both are broken. You can either fix the wires or get a new shifter for about $50.
#53
thanks your right it is overdrive
#54
hate to revive an old thread but have a question on difference between
Tow/Haul and overdrive button on 2003 f-250 crew 7.3L. My brother in law has a 2011 6.7L with nice trailer brake control on stick so i am guessing he has the true tow/haul mode..
I have driven a 6.0L chev with tow/haul button we pushed when heavy loaded.. never did pull a trailer. it allowed the engine to rev more and think it locked out high or overdrive gear.
crap noticed this was wrong forum.. sorry should be in 7.3L PS
#55
#56
#58
The way U-Haul does it is that they buy enough vehicles that Ford developed unique calibrations that did this for them.
#59
How does that(OD) work with the torque converter when you hit the brake? the reason i ask is i have read post talking about locking up the TC when you touch the brakes and unlocks when you give it gas??
confused.
PS this is a new to me truck. 2003 lariet, crew, 2wd, 6.5 bed no mods so far.
I did get a 6.0 trans cooler that i want to change out at some point. not going to be doing any real towing for a couple years.
I do enjoy your post and thanks for your expert help.
#60
