TOW/HAUL- any way to set as start up default??? - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 08-18-2014, 09:30 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Quote:
Originally Posted by carl2591 View Post
so is there any advantage/ disadvantage in turning off OD when towing?.
The isn't an advantage that I know of turning off overdrive when towing. It will burn more fuel.
How does that(OD) work with the torque converter when you hit the brake? the reason i ask is i have read post talking about locking up the TC when you touch the brakes and unlocks when you give it gas??
Overdrive and the torque converter are two different things. The converter will lock and unlock regardless of overdrive.
Overdrive is fourth gear. It is like any other gear in the transmission except that it's ratio is greater than 1:1. It isn't some magical thing, it's just another gear ratio.
The torque converter has a clutch inside that when locked makes a mechanical coupling between the engine and transmission. When it is unlocked there is a fluid coupling between the engine and transmission.
There is a lot more about how transmissions work at HowStuffWorks "How Automatic Transmissions Work"
  #62
Old 08-18-2014, 09:30 PM
carl2591's Avatar
carl2591 carl2591 is offline
carl2591 is gaining momentum as a positive member of FTE.
OK now i sorta "get it" on torque converters and how they work.
actually the "how things work" video is sorta lame. I found a couple that make more sense. here is a good one.
It seems the lockup is controlled by the computer by reducing the pressure of fluid going into the converter allowing the lock up clutch to engage the face?of the converter.
SO, i have read where some programs you can get, will if equipped with exhaust brake, cause the TC to lock up during the exhaust braking to help slow the vehicle down so when going down hill with a load.
I also see where the more expensive TC has 2, 3 or sometime 5 clutches in them. I guess a standard f-250 from factory has 1 or maybe 2 clutches in the TC and when pulling a load you can get more slippage creating heat and wear.
What is a good HD type TC to get that will get along good with the 4R100 trans in stock form or should you be looking to upgrade trans (BT) and TC at same time.
thanks for your time.
Using Tow/Haul Option nygiants4ever Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 3 01-12-2017 11:27 AM
Tow/Haul & Exhaust Brake rdlouks 1999 to 2016 Super Duty 2 08-21-2016 09:39 PM
Tow mode engine braking jd350b 6.7L Power Stroke Diesel 11 06-11-2016 10:45 PM
Tow/Haul with SCT Tuner. KW7DSP 1999 to 2016 Super Duty 9 10-10-2015 02:58 PM
Always use tow/haul in a 12,000-pound ambulance? lwems 6.0L Power Stroke Diesel 13 04-28-2013 01:10 PM
Tags
analyzer, ford, haul, injector, injectors, intermotive, itself, light, modification, on, overdrive, performance, products, psd, ranger, switch, tow
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
