French Ford Flatheads -- new castings, SAE threads
Old 04-20-2003, 07:36 PM
mlf72f250's Avatar
mlf72f250
mlf72f250 is offline
I was researching flathead fords for a future project and ran across this:
http://www.halibrand.com/flathead_info.htm#GENERAL
They have newer Ford flathead castings, from French military surplus. Not cheap, but most dimensions and SAE thread sizes are preserved (no metric).
It just blew me away that they had used these up until the early 1990s, but I suppose in some applications, the flathead is more compact...
--Matt
Old 11-02-2004, 10:03 PM
devja's Avatar
devja
devja is offline
..I read that somewhere too. If I remember, the France got the rights to the flatty and made it up till the late 80's. I think they were cast steel though and not cast iron. So I've read.
Old 11-11-2004, 07:53 PM
LedheadELH's Avatar
LedheadELH
LedheadELH is offline
Flathead ???s
I was looking around in this junkyard that is seldom ever visited by anyone other than me and a couple others, and I found 2 Flathead V-8's. On had the distributer in the front, and the other had the distributer on the top. what is the difference between these 2 motors, and which one would be better for a build-up?
Old 11-13-2004, 08:35 PM
ptmilan's Avatar
ptmilan
ptmilan is offline
The distributer on the front was used from 1932-1948. The distributer on top was used on the 1949-1953 models. I don't know what it takes to interchange the 2 types. The early ones had an enclosed driveshaft. While the later models (49-53) had an open driveshaft.
Old 11-25-2004, 09:50 AM
captchas's Avatar
captchas
captchas is offline
Guest
the inclosed drive shaft was called a torqe tube by most
ChristiansenP
06-15-2016 05:03 PM
CarlT100
VetNet
06-19-2015 05:38 PM
maxtegracing
43
08-03-2013 07:45 PM
trfisher5
1947 and Older Ford Trucks
09-30-2011 09:47 PM
jmadsen
Flathead V8 & Flathead 6
04-16-2008 12:17 AM
Quick Reply: French Ford Flatheads -- new castings, SAE threads
