Forged piston and cast piston weight diff
Originally Posted by baddad457
Doesn't matter, just as long as you weighed each the same way. Might be able to swap out the pins between the sets to get them to weigh closer to the same. Weigh a few pins from each to see if they're different.
And, there was some difference...
Above all else, I wouldn't use used wrist pins unless they were pristine and I HAD to. Especially with mixed manufacturers.
The wrist pins look very good that came with these used forged pistons. I removed the rods from the pistons myself and inspected each wrist pin and rod bushing before and after disassembly. They both seemed to be in almost perfect condition and had no play. I even measured the pins with a micrometer and can't find any variances in them anywhere.
I'll weigh the wrist pins from each set of pistons and post what I find.
waltcujo
06-27-2013 01:15 PM
IHATERUST
03-07-2006 11:48 PM
teederj2002
01-21-2005 05:56 PM
d9t351_400
50
07-08-2004 10:23 PM
67 428 Fairlane Ranchero
01-30-2003 08:12 PM
