My F150 is being painted for the 5th time, now what?
My truck has been painted 4 times already for a spot that was the size of my thumb on the passenger bed side. Everytime I have gone to pick it up, something was wrong with it, clear coat on the bumper, air bubbles under the decal, fisheyed paint, and now a softball sized dent (where the thumb sized spot was), not to mention that the two tone paint isn't matched smooth, and also the bedside is 3 shades of black! The dealer doesn't paint the trucks, but sends them off. I have offered to give them one more shot at it since they were willing to pay a little extra to send it to someone else. If my truck comes back looking like crap, what can I do?
What was the first thumb sized spot like? A dent, scratch, haze, dull spot? Did you put it there or did it happen in a parking lot? Did you buy it that way? If it bothers you that bad trade it in or sell it and get another or have them take it to whomever you want to paint it. If it comes back from the new place the same way maybe your just paranoid and looking for a problem. I don't mean it in a bad way some times things like that can just drive you crazy.
I had a problem with the paint on my truck when new. It's two-tone and there was some of the primary paint shining through the darker paint. It was very obvious since my colors are yellow and grey. I was very nervous about the dealer painting this part since it probably would not be the same as original. I went to pick it up and it was awful ( just as I imagined). Fortunately, the second time worked out much better. I know what you're going through. I can only hope that the fifth time will be your last. Best of luck!
If it were my truck, I would try and speak to the manager/owner and try to get them to agree that I can use my body shop (since I know reputable ones) and have them cover the cost. That way you can take it up directly with the monkies doing the painting if it goes wrong again and not deal with the middle man (dealer in this case).
T
T
Here's an update and an answer to some of your questions.
The truck is a scab, and the hole is located a few inches in front of the passenger side tail light. The spot was centered on the bed. I bought the truck in February, and it had 17000 miles on it when I last saw it. It wasn't the little spot that bothered me, but the fact that my bed was going to eventually rust through.
The truck is STILL in the shop, and has been for all but 2 weeks since October 4. I have had an 99 F150 from the dealer since the early part of November. The truck is supposed to be finished on Monday, we'll see.
I do know that this is the last chance they have to fix it. It either looks brand new, or I'm getting a new truck, I sick and tired of being nice about it.
Oh, and mountainman, if they have to take it back, I'll give you their address and you can go do whatever you want with it!
There is a large butyl patch in that area on both sides of the truck box outer (I think you can see it through the wheel well). The patch may have not taken to the metal during curing and water has been trapped behind it causing it to rust through. In addition to fixing your problem, the patch should be removed, a rust inhibitor applied, and the area should be repainted. Might want to have them do it to both sides. Haven't seen a TSB on it yet.
Yeah, I thought I mentioned the pad, but must have left it out. That's exactly what caused the problem. Can you believe it? A piece of freaking padding!!
They hadn't even removed it the first 4 times, and I let them know about it. I didn't get the chance to call today, but drove by after they were closed. My truck wasn't there.
By the way, isn't the padding just sound deadning material?
Could try and get them to order a pre-painted bed from the factory. Since the body putty didn't set right in one area you most likely will have problems all over, they don't hand clean each area before puttying. The bed is either dipped or spray cleaned. PS The bed may not match exactly either, as temperature and humidity at spray times can make minor changes to the paint color.
Thanks lardman, for the explanation of the padding.
The truck is still not back. I called today, and since "my service advisor" was gone, they couldn't tell me anything. I am ****ed!! I just wish I could get out from under the loan, and forget the whole thing ever happened. I'm patient, but 2 freaking months, and over $1200 in truck payments, and I'm driving a 99' beater 2wd!!
They told me that Ford didn't ship prepainted parts, and that they'd only ship the bed in pieces anyway. Any truth to that?
Have a friend and his 2001 tailgate wasn't welded along an edge, he compared it to mine. The replacement was sent out of the factory fully assembled, lock was even correct, and painted. Also it seems I remember it being posted the Hoods are shipped already painted. The 4 X 4 wheel molding is shipped already painted.
