Airbag Flashing Code
When you say the warning lamp, I assume you mean the light in the Passneger Airbag On/Off Switch.
What is involved in changing this bulb?? I popped the thing open hoping for a 194, but instead I found a LED (I think). It's soldered onto the board.
If it's shorted, what would constitute a short?? Bare wire somewhere touching metal?
And if I fix the problem, will the light automatically quit flashing, or do I need to take it to the Dealership to get it reset?? (I hope not...)
When I said inoperative I meant the circuit is not functioning correctly, you would need to run the pinpoint tests to determine the exact cause. Sorry about the confusion, since it was flashing I didn't think it would be interpreted that way. Below is a listing of the PPT.
Pinpoint Tests — Air Bag Supplemental Restraint System (SRS)
PINPOINT TEST O: LFC 27/DTC B1884 — PASSENGER AIR BAG DEACTIVATION (PAD) WARNING LAMP INOPERATIVE
² O1: CHECK FOR A HARD OR INTERMITTENT DTC
² O2: CHECK THE PAD SWITCH WARNING LAMP VOLTAGE
² O3: CHECK CIRCUIT 1113 (YE/LG) FOR A SHORT TO GROUND
² O4: CHECK CIRCUIT 1113 (YE/LG) FOR AN OPEN
² O5: CHECK FOR AN INTERMITTENT FAULT
² O6: CHECK FOR ADDITIONAL DTCS
PINPOINT TEST P: LFC 27/DTC B1890 — PASSENGER AIR BAG DEACTIVATION (PAD) WARNING LAMP SHORT TO BATTERY
² P1: CHECK FOR A HARD OR INTERMITTENT DTC
² P2: CHECK THE PAD SWITCH WARNING LAMP
² P3: CHECK CIRCUIT 1113 (YE/LG) FOR A SHORT TO BATTERY
² P4: CHECK FOR AN INTERMITTENT FAULT
² P5: CHECK FOR ADDITIONAL DTCS
>Just my opinion, but I would take it to the dealer. When it
>comes to airbags, that's something I don't mess with. And,
>I really don't think the warning lamp is shorted if it is
>flashing a code.
Thats what the code 27 means, see my previous post from the Ford manual.
>flashing a code.
underDAWG
22
06-24-2006 10:46 PM
