2000 f 150 door panel removal and speakers. - Ford Truck Enthusiasts Forums
Old 11-13-2004, 01:08 PM
stockf150stlyeside stockf150stlyeside is offline
stockf150stlyeside is starting off with a positive reputation.
i have a 2000 f 150 and need to remove the door panel to replace the speakers in the doors. how would i go about doing this? i would also like to know the speaker size.
thanks for the help
Old 11-13-2004, 04:33 PM
triton_2002's Avatar
triton_2002 triton_2002 is offline
triton_2002 is starting off with a positive reputation.
The speaker size is 5X7 or 6x8, both will fit. The door panel comes off pretty easy. The top vertical piece just pull off with a firm pull. There is one screw under that. If you have power windows/locks, remove that piece. Use a flat screwdriver with some tape on the tip to prevent scratches. Once you pop off the switches, remove the connectors from underneath. The trim piece around the door handle also pops out, if you look carefull around the edge there is a little slot to pop it out. There are one or two screws there. That's it, now pull the entire panel UP and out, do not pull it straight out or you might break off the tabs that hold it in. Don't pull it completely off yet, disconnect that little light in the side of the panel.
If you have manual windows, the window crank handle comes apart into two pieces. Carefully pry the cover off and it swings out of the way, there is one torx screw in the crank handle.
That's it, take your time and it's easy.
Old 11-13-2004, 05:20 PM
thank you very much. i have acomplished the task now all i have left is to replace the speakers with new better quality ones.
Old 11-14-2004, 06:02 PM
are you replacing the head unit too? If you are just upgrading the speakers, don't get some that require alot of power, as the stock head unit is not too powerfull.
Old 11-15-2004, 04:59 PM
yes the head unit will be replace by the end of december. im getting a pinoeer head unit. the double din sized one i forget the number. the sound system is being set up by myself for db racing!!!
Front Door Speaker Replacement- Door Panel Removal Procedure makuloco2000 2009 - 2014 F150 9 01-12-2015 10:56 PM
Door speakers 1996 F250 fleetsidebob 1987 - 1996 F150 & Larger F-Series Trucks 5 04-07-2013 10:07 PM
removing door panel on a 2003 f150 tutiii 1997 - 2003 F150 2 09-17-2007 09:41 AM
help installing rear speakers f250 c/c fyrbolt Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 3 02-07-2005 07:22 PM
97 F150 left rear panel removal Inita fix my F150 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 1 04-28-2003 09:24 PM
Tags
150, 2000, 2001, 2005, door, f150, install, manual, panel, removal, remove, removing, speaker, speakers, supercrew, window, windows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
