4.9 6 Cyl Flywheel Bolt Torque Specs? - Ford Truck Enthusiasts Forums
Old 11-13-2004, 10:49 AM
skid2964 skid2964 is offline
skid2964 is starting off with a positive reputation.
I cant find this info ... anyone have it? Im replacing my clutch and I am now ready to bolt the flywheel back in and I cannot find the torque specs!
Thanks
Old 11-13-2004, 12:34 PM
srod srod is offline
srod is starting off with a positive reputation.
Quote:
Thanks
my Chilton book only goes to 1986 but those years on down are all the same for the 300-6
(flywheel to crankshaft bolts) 75 to 85 ft. lbs.
1981 Ford F100 Custom short box inline
Old 11-13-2004, 07:11 PM
Ladyfire3374 Ladyfire3374 is offline
Ladyfire3374 is starting off with a positive reputation.
The factory manual for my 1993 says:
75-85 ft-lbs for the flywheel to crankshaft bolts in the I-6.
flywheel torque specs??? Tomahawk2506 1967 - 1972 F-100 & Larger F-Series Trucks 1 06-03-2013 10:05 PM
Dana 80 torque specs on cover bolts? PLNTKLR 1987 - 1996 F150 & Larger F-Series Trucks 2 12-29-2009 03:14 PM
97 ranger flywheel torque specs HogginNboggin9 Ranger & B-Series 0 10-05-2009 07:16 AM
torque specs for flywheel bolts on a 390 chico76 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 10-06-2004 08:28 PM
Torque specs on flywheel f150 gurl FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 4 06-16-2004 02:06 PM
Tags
1981, 1996, 49, 6l, 93, bolt, clutch, cyl, f100, flywheel, ford, liter, secuence, spec, specs, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
