2000 F-150 GEM Module location - Ford Truck Enthusiasts Forums
Old 11-13-2004, 10:00 AM
top37mustang top37mustang is offline
top37mustang is starting off with a positive reputation.
Question 2000 F-150 GEM Module location
Does anyone know where exactly the GEM Module is located on my 2000 f150? I need to replace it but have conflicting info on the location. Someone told me it was behind the instument panel and another said behind the fuse box...
Any info would be greatly appreciated.
Thanks!
Old 11-13-2004, 10:48 AM
shotgunner426 shotgunner426 is offline
shotgunner426 is starting off with a positive reputation.
If you are talking about the GEM module for your 4wheel drive , mine is a 98 and is located on drivers side up under dash behind fuse box. I think mine is bad but have not priced one yet. Do you know what one cost and have you checked Fordpartsonline for a price.
Old 11-13-2004, 03:22 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Hi top37 and welcome
The GEM is attached to the back of the fuse box. You remove them both at the same time.
Old 11-13-2004, 04:07 PM
super440 super440 is offline
super440 is starting off with a positive reputation.
I'm curious as to why you need to replace it. Is it because accessories like the radio or blower fan are coming on by themselves, strange things like that. I have seen quite a few like this, the main problem for that is water leaking into the gem. Just a thought.
Old 11-14-2004, 03:02 PM
Hello,
Thanks for all your info. I brought my truck to my local Ford dealer because the drivers side power window stopped working, the passenger window will only work intermittenly as well. The Ford Tech told me they did a scan and found the GEM Module was bad, they too also said it was most likely cause by a water leak. They told me its going to cost between $300 and $325 to fix it with labor. I have connections with another Ford garage thats out of state that ill be getting the parts from. My cost is going to be about $110. It soundslike a big job, anyone attempt this yet? When I get done with my repairs ill let you all know how it went.
Thanks again.
Old 11-14-2004, 06:52 PM
Racerguy's Avatar
Replacing the GEM is a bit of a pain in the neck but not terribly bad.
If there is any possibility that the windshield leaks make sure you get that resealed first. You don't want to kill a second GEM.
GEM module location? plgebbia 1999 - 2003 7.3L Power Stroke Diesel 7 07-26-2011 07:00 PM
where's the gem module jlcparis Excursion - King of SUVs 1 04-23-2010 03:48 PM
GEM module location sleepyhead416 1999 to 2016 Super Duty 3 03-07-2010 07:17 PM
2000 f250 gem module nafire 1999 to 2016 Super Duty 1 06-30-2008 08:28 PM
GEM Module mikeyh39 Electrical Systems/Wiring 4 05-28-2003 09:44 PM
Tags
150, 2000, 2003, 2005, 4wheeldrive, 98, body, f150, ford, gem, located, location, modul, module, remove, replace
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
