OIL Dipstick? - Ford Truck Enthusiasts Forums
OIL Dipstick?
Old 11-12-2004, 11:08 PM
BLACK350/6.0L BLACK350/6.0L is offline
BLACK350/6.0L is starting off with a positive reputation.
OIL Dipstick?
Anyone know of a good aftermarket dipstick for the 6.0L? Or a mod that would make that engineering masterpiece easier to read? I swear I have to check the oil a dozen times to get a good reading... Thanks in advance!!
Old 11-12-2004, 11:34 PM
Daryl Hunter's Avatar
Daryl Hunter Daryl Hunter is offline
Daryl Hunter is gaining momentum as a positive member of FTE.
Some guys did talk about painting it with a white epoxy paint and that helped them a lot. One of these days when I remember I'll pick some up when I'm at the hardware store.
Old 11-13-2004, 12:24 AM
jimmy-six's Avatar
jimmy-six jimmy-six is offline
jimmy-six is starting off with a positive reputation.
I used "white out" worked great....
Old 11-13-2004, 02:39 AM
riceburner riceburner is offline
riceburner is starting off with a positive reputation.
just drive up to the dealer and tell them the dip stick broke from the T. they should give you a new one with a white tip from the 04 model.
Old 11-13-2004, 09:25 AM
Bear Hunter's Avatar
Bear Hunter Bear Hunter is offline
Bear Hunter is gaining momentum as a positive member of FTE.Bear Hunter is gaining momentum as a positive member of FTE.
Quote:
Hmm...I have an 04 and the tip is grey. I don't know if I would mess with painting something and then sticking it back in my engine.
Old 11-13-2004, 10:23 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
Get the Gray one it is great....had to change mine form the black one...lets see black oil black dipstick....someone is still laughing about that one.
Old 11-13-2004, 02:50 PM
jimmy-six's Avatar
Mine is the gray one on my 04. I still painted the back side of it white with white out after roughing up the plastic...Ever tried to get that stuff off anything? Works great.
Old 11-13-2004, 10:24 PM
Will give the white out a try thanks for the tip!!
Old 11-13-2004, 10:53 PM
SBV45's Avatar
SBV45 SBV45 is offline
SBV45 is gaining momentum as a positive member of FTE.
I wouldn't use white out. I would go buy a can of high temp engine or exhaust paint.
Old 11-13-2004, 10:56 PM
I'm going to give it a shot too. I figure that even if it does come off, the minute amount of it on there won't cause any grief.
I would think that the paint would be better to use, but since I have some whiteout handy right now . . .
Old 11-14-2004, 08:00 AM
IB Tim's Avatar
Site Administrator
The Gray one is cheap......
Old 11-14-2004, 09:42 AM
I still wouldn't paint it
Old 11-14-2004, 01:35 PM
The Barts The Barts is offline
The Barts is starting off with a positive reputation.
I pick up my new 2005 F350 SC LB 4x4 DRW 6.0L 4.10 two weeks ago and the oil was always over the max on the stick. After 4 days of trying to find the the oil mark I couldn't take it any more. So I went out and picked up 16Qts of Rotella 15-40 and a new filter. I but the truck on level ground removed the dip stick and drained the oil.When the pan was done draining I drained the filter housing and replaced the filter. When the pan stopped draining I put the plug back in. I then put in 12Qts of oil and ran the truck for 3mins.and then truned the engine off. I than went in the house and made a cup of coffee and after 15mins went back out and picked up the dip stick off of my work bench and check the oil. It was at the min line. I now put in 1 and a 1/3 Qts. Let it set for 5mins and rechecked the oil and it was at 1/2 way between min and max. I did not add any more oil. I've checked it every day for the last 5 days and it's easy to see and always 1/2 way between min and max.
Old 11-14-2004, 08:32 PM
SBV45's Avatar
Another testimony to hazards of overfilling and only refilling with 13.5 quarts of oil.
Old 11-14-2004, 09:33 PM
me1mckee's Avatar
me1mckee me1mckee is offline
me1mckee is starting off with a positive reputation.
Yeah Tim, someone is definitely chuckling about that one.
2 Dipsticks?? 460 FORD MAN 1973 - 1979 F-100 & Larger F-Series Trucks 27 01-28-2015 12:47 PM
Oil capacity shouldn't be this difficult? Widetrack455 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 07-10-2014 02:33 PM
updated 6.0 oil dipstick? Robby Nash 6.0L Power Stroke Diesel 2 03-07-2014 03:20 PM
New oil dipstick for earlier 6.7. CascadeF250 6.7L Power Stroke Diesel 19 11-13-2013 09:01 AM
Oil dipstick accurate? XXL Supreme Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 0 03-09-2006 10:07 AM
Tags
2003, 2004, 60, 60l, diesel, dip, dipstick, engine, f250, f350, ford, oil, powerstroke, stick
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
