my trucks doesnt want to run again... please help me out!
when i have like a full tank, it runs like a charm... and when it gets about down to a quarter tank it it doesnt want to run at all... but then when i shut it off for a couple minutes and start it again it will run good for like 2 minutes... then crappy again... and then when i have like an like less than a quarter tank it runs fine again... and it does this on both tanks.... and it is really pissin me off.... well i hope someone out there has a solution.. thanks
tony
tony
Fuel pump. I don't know if your model has it in the tank or out or both, but it sounds like a fuel delivery problem.
Check your spark plugs. If they're burned white that means the motor is running lean. Could be a clogged fuel filter or a fuel pump running weak.
cb
cb
I'll put my vote in for a faulty fuel pump. I had a similar problem a few years ago. No one believed that it would be the fuel pump. "They just don't go bad that way". The pump is an electric motor and it has wires. Apparently when it was built the wiring was faulty so sometimes it would conduct electricity and sometimes it wouldn't. It was bad news because I could be out in the "Boonies" and suddenly the engine would sputter and stop. Come back 2 hours later and it would start. Then I could run it a thousand miles before it would happen again (quit again). We changed all kinds of sensors and ignition parts before we finally conceded that it must be the pump. Which it was.
Bob P.
Bob P.
John Main
03-23-2017 08:15 PM
mastermidnight
08-28-2016 09:12 PM
AHoldgate
1997-2006 Expedition & Navigator
05-31-2014 10:59 AM
porktornado
Modular V8 (4.6L, 5.4L)
06-08-2012 05:53 AM
