Poor Keyless Entry Range
I have the factory keyless entry on my '03 F-250 SuperCab. I have always had to be within about 5'-8' of my cab to get the doors to lock/unlock. I thought it was normal for the longest time, but recently learned it's not. I am out of warranty now so I need to try and fix this myself. Does anyone know the location of the receiver module, and what it looks like? Also, is there an external antenna w/ the factory keyless entry, and where is it at? Transmitters are fine, as is battery power. Only think it could be is receiver/antenna.
thanks - Shawn
thanks - Shawn
And I Thought That My 2002 Was Weak...
My keyless works out to at least @100ft. My friends 2002 F150 works much further than mine. If I am not mistaken, my keyless entry receives the signal from the remote at a small smoke colored, dome shaped antennae on the top center of my dash right next to the windshield.
My keyless works from about 30' away. It used to work from about 100.. but yeah.
__________________
2002 F-350 XLT 4x4 PSD 6spd SC SB SRW
2001 400ex SportTrax
1990 F-150 Lariat 4x4 I-6 5spd RC SB
---Also in Family---
2003 F-250 XLT FX4 6.0PSD TSA SC SB
2001 F-150 XLT 4x4 5.4 AT SC SB
I'm not sure of the manufaturer of mine, but it was installed on the truck as an option when I bought it. It's terrible, I used to have to be pointing it in the window for it to open. I have since found the receiver and unrolled the antenna and now it works from 5-8' away, which sadly I am happy with. My receiver is a small box about 2"Wx2"Lx.5"H with a small wire sticking out of it. It was never mounted (go figure) so the wire was wrapped in a mouting hole. After unravelling it, my reception improved. My box was located just above the pedals and below the fuse box. I would think yours is in the same vicinity. Oh and I have an '02 F-350.
Before laughing about it, just try it!!!! I was reading in the 6.0 forum and they were discussing the subject of unlocking your car via your cell phone and low and behold here comes what I thought to be the most ridiculous suggestion ever, which was to "stick the fob under your chin and your head will work as an antenna".
Funny enough, 2 days later I am walking away from the truck ~100 feet +/- and remembered I had forgotten to lock it. Tried about 15 times reaching as high as I could, going sideways and even trying it upside down and nothing worked.....until I stuck the remote under my chin, and two hits later I heard the familiar honk from the horn. To be sure I used the same procedure to unlock the truck and tried to lock it again keeping it close to me, reaching high, going sideways and nothing worked....until I stuck the remote under my chin.
Go figure??
Claude
Go figure??
Claude
Shawn
on
I'm sure that you've done this already, but it, usually, doesn't hurt to ask. Have you made sure that you have a fresh battery in your remote? Also, I'm sure that you have tried the second key fob to make sure that the distances at which they work are about the same?
If the second key works only to the same range as the first then you've definitely got a receiver problem. My '03 works out to about 50' pretty well.
The under-the-chin thing really works. The Car Guys talked about this with a physicist a while back. Something about your body as a low gain antenna. Whatever. It works. Just don't let "outsiders" see you doing this...
Be sure the battery is fresh. I swap fobs after a while until the second one starts to weaken and then get new batteries. They usually last about a year.
I believe Shawn has tried new batteries (saw his plea for help on another site). Only thing I can think of is an antenna issue, where the antenna wire is too close to some metal or something that's shielding it from the fob signal. Unfortunately, I've nver explored the keyless entry system, so I'm just guessing.
Go figure??
Claude
Go figure??
Claude
Did you DOUBT us !?!?!?!!?
I am HURT....
tragically hurt
You just have to perfect the move to not look like a complete idiot in the restaurant when you do it....
Usually a chin scratch can be held long enough to get away with it
Yes, I've changed batteries. Both fobs have identical performance, the head trick gains nothing noticable. I have ruled out everything but a receiver/antenna problem. I just need to find them. I sat underneath my dash for about 10 minutes last night listening for a relay click or something while pushing the fob buttons. I thought I could hear something up behind the radio, but I am not sure. I've got a service DVD on the way, but I doubt that is going to be much help either.
Shawn
Shawn
