Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-09-2004, 08:29 PM
puddlewatcher puddlewatcher is offline
Garage is empty, add now
puddlewatcher is starting off with a positive reputation.
65 ranchero engine swap ?'s
hello everyone. just recently found this site. i was wondering if anyone could help me with some questions. Is a 300 a good engine to put into a 1965 falcon racnhero(200)? If so, what major projects would come along with doing so? im only 16, so i havent had that much experience. My father and i bought this to fix up(just some rusted floor boards and other minor things). now that i have a job im planning on putting more money into this. Any help is appreciated. and if theres a better place for me to post this, that might help as well. thank you
  #2 (permalink)
Old 11-09-2004, 08:31 PM
i forgot about the ranchero and econoline threads....my bad
  #3 (permalink)
Old 11-12-2004, 06:20 AM
65rancheroguy 65rancheroguy is offline
65rancheroguy is starting off with a positive reputation.
If your going to all the trouble to pull an engine and re-install, why not go to a 289/302. It wouldn't be that much more money and you'd be much happier with the end result.
Just my $.02 worth.
Good luck in whatever you do with it.
  #4 (permalink)
Old 11-12-2004, 12:11 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
Ditto. 300 is long, tall and heavy. Revs to 3500 unless you fool with it.
289-302, much more flexible motor, only missing the idle to 2000 rpm torque of the 300. But your '65 is a featherweight and you'll be fine (as have been 10's of thousands before you) with a 289 or 302.
  #5 (permalink)
Old 12-27-2004, 05:05 PM
stevef100s stevef100s is offline
stevef100s is new and has a neutral reputation at this point.
I had a 65 Ranchero that came stock with a 289 4 barrel, with T-10 close ratio 4 speed. I built it up a little, and sometimes ran a 4.11 locking 8" rear diff. I went to 15" 60 series tires, and that little sucker would nearly pull the front tires off the ground. It WOULD have with slicks, or broke drivetrain parts.
Tags
1965, 200, 289, 300, 302, 65, 67, engine, falcon, ford, put, ranchero, swap, switch, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
