79 gas mileage
79 gas mileage
Hey this is my first time submitting a question, but just wondered if any one knew if there is a big difference in gas mileage between an 79 F-250 and 350 4x4 standard cab my dad used to own a 76 ford that he made look more like a 79 and used it mainly to spray our fields with, when we moved he sold it. I also didnt know if anyone knew how much better gas mileage an older 7.3L diesel f-250 or 350 might have and the difference between the two. I also realize that in the gas the engine matters so how about a 390 comparison and also a 460, I hope Im making sense and thanks for your comments
OK 1st post so I will go easy and welcome to the forum.
Those 2 truck's would get the same exact mileage depending on if they have the same motor, trans and gear's.
What year are you talking about? They did not offer a diesel from the factory in the 73-79 F-series.
I would think the 460 would use more gas than an FE motor but not a 100% sure.
I have had 4 f-series trucks,mpg as follows:1984-f150 300 4-sp overdrive--about 17mpg
1973-f100 360 2bbl,AT low geared --about 10mpg
1979-F150 4x4 351m,AT,3:50gears,33's--about 10mpg
1990-f350 dually,4dr,460 AT overdrive,4:10--about 10mpg
These are averages,not on interstate at 55.---The dually once got 13,empty,4 adults on interstate.
My little contour once got 41mpg on a downhill stretch on i-40 but EVERYDAY average,no interstate,is about 26mpg.
Hey thanks for your comments, yeah I realize about Ford not making the diesel in the 79 model but just was wondering the difference between a 7.3 L diesel F-250 and 350, not between the gas and diesel, sorry about the confusion
https://www.ford-trucks.com/forums/s...ht=fuel+economy
Here is my take on Fuel mileage.
By the time you are finished reading this you will be able to answer this question
This chart is for any engine/vehicle combination.
Considering the FACT there are so many variables regarding fuel economy it would be hard to get a specific answer.
Things to consider:
1)Quality of Fuel
2)Additives
3)Tune & Efficiency of Engine
4)Altitude
5)Driving technique
6)Topography where you are driving
7)How much city/how much highway driving
8)Gear ratio & size of tires
9)Weight of the vehicle
10)Tire inflation
11)Vehicle design (drag)
12)Clean air filter
Just to name a few.
I drive a 78 pickup with a well tuned 429 engine,at an altitude of 3400 ft above sea level,with normal weight on the truck with a canopy,tires inflated to spec,using premium fuel,2.75 rear,C6 Trans, With my foot on the pedal like there was a egg under it, in Canada in a city that the downtown is located in a valley.
I get 14 city & 18-19 hwy.
Does this help ?
Things to consider:
1)Quality of Fuel
2)Additives
4)Altitude
5)Driving technique
10)Tire inflation
12)Clean air filter
Just to name a few.
Does this help ?
