gas vs. diesel
gas vs. diesel
I am considering a new F250 and I am wondering if I should go diesel or gas. I will be getting a standard transmission in it either way, because I prefer them to automatics. I was leaning toward the diesel because of the horror stories I have heard about gas mileage from the Ford V8 gas engines but I am wondering if it is worth it now because of the high cost of diesel fuel. I do not tow anything that heavy and I put anywhere from 10k to 15k a year and usually keep a truck about 10 years. Any info would be appreciated.
Thanks
Gary_k
Thanks
Gary_k
Do a search on this topic you will find tons of info. I know this has been asked at least 3 times in the last 2-3 weeks. It really comes down to what you will use the truck for and what you prefer. I don't know what type of gas mileage the V-8's are getting but on my V-10 I'm getting arount 13-14 MPG in city and anywhere from 15-17 on highway. If costs is a determining factor the gassers don't get as good MPG as the diesels but you also have to consider it does cost more to maintain a diesel than a gasser and it's about 5k more for the diesel. Either way you go you can't make a wrong decision they're all great trucks. Good luck on your decision
get the diesel you'll be glad you did!!! and keep your fingers crossed that diesel will go down again in price. hopefully back below the cost of 87 octane very soon!!!!!!!! a little side note the longevity of a diesel to a gas motor is incredible if you plan to rack up the miles go with the psd all the way.
on
Steam, then hydrogen oxygen, then gasoline, then diesel.
Which came first though does not answer the question of which is better.
Best to search through the ample posts on the topic, do the research, and then buy the diesel and add a tuner
Seriously though, it really depends upon what you are going to use the truck for and on how long you plan on keeping it.
I keep seeing people post that it costs more to maintain a diesel truck than a gas truck. I would really like to know some of the facts these statements are based on, because both diesel trucks I have owned have certainly been cheaper to maintain than the gas trucks I have had. Please enlighten me with real information, not the "I heard" or "I imagine" stuff.
on
I think that Pikachu's post was more directed at the maintance costs like oil and oil filter changes, air and fuel filter changes, etc.
The direct operating costs per mile for fuel is pretty straight forward to compare between the two given cost of fuel and mileage. The maintenance costs to keep the diesel running over that of the V10 is what is being questioned.
Let's hear some real maint cost numbers per 50,000 miles or 100,000 miles for each motor.
I have 2 two V10s, the DRW has 42K on it the only service have been oil changes every 4 to 5 K, M1 with filter 26.30 total, air filter is K&N. The SRW has 75K the same service as the DRW. If they run as good at 100K I won't even do the plug change. I don't just drive them empty ether, DRW 15K 5ver, SRW weighs 9K+ all the time.
Denny
Denny
In 2000 I bought a 4.6 gasser with 4R70 tranny in an F150 Supercab 4X4 short box with 3.55 gearing. Being a small V-8 it should have got good gas mileage - NOT. And aside from that, it wouldn't pull #$%^. I have an Airstream, and was doing hills in low gear to avoid tranny death. In 2002 I traded the 4.6 with only 9,000 miles on it for a 5.4 with 4R100 tranny, 3.73 gears in the same body style but in a 7700 model (F150 Supercab Short Box 4X4) It got better fuel mileage and pulled my Airstream pretty good. While test driving trucks in 2002 I tried out an F250 Superduty Supercab Shortbox 4X4 with the 5.4, and I liked the F150/7700 better. Now we get to the end of the story. This year, 2004, I finally made the step and got an F250 Superduty, Supercab, Short Box, 4X4, 6.0L, Torqueshift 5 speed auto, 3.73 gears, and I now can speak from owning all of the Ford V-8s except the 7.3, which must be a wonderful motor, because this 6.0 is really something. Moral of the story? I won't go back to gas. AND this diesel pulls my Airstream like it wasn't even there. AND it goes like a scared rabbit. AND it gets better fuel mileage with my heavy foot than any of the other ones did when I drove like I had all my marbles (which I have never been accused of having) If this don't convince you to buy the diesel, then go buy a gasser and suffer the consequences. (happpiness and contentment if you want one) Really, the way I see it - if yur askin', ya must want a diesel.
1. How much does it cost for an oil change v10? (number of quarts plus oil filter and how often does change occur)
2. How much does it cost for an oil change 6.0L? (number of quarts plus oil filter and how often does change occur)
3. How much does it cost for fuel filter v10? (how often does change occur)
4. How much does it cost for fuel filter 6.0L? (how often does change occur)
Now...lets also factor in the duration for each above. We should all be using the FORD recommended Severe maint. schedule. Plus all work is done by owner. We will not consider "shop" involvement here...as different shops charge differently.
Any input is appreciated...lets see the numbers, so that we can get a true idea of cost of ownership here.
In 2002 I Had This Same Issue...
I was at the same place that you are at right now, back in 2002. I didn't need the diesel, just thought that I wanted it. The extra price for the diesel engine had me going back and forth from gas to diesel, back to gas. One evening, I even ordered a gas super duty from my dealer, thinking that I finally had made my mind up. Well I hadn't, I called the dealer the next morning and ended up cancelling the order and bought the 6 speed diesel truck that I had test drove before. I don't buy new trucks very often (still have my old one) and I got to thinking that evening before that I really wanted the diesel and I was just trying to save the money. I deceided on the diesel and am glad that I did, gotta love the PSD engine. You will find people here that have good opinions on the gas and the diesel engines and everyone likes their own truck, which can be expected. Either way, they are both FORDS, so how can you go wrong! Just Buy What You Really Want.
