2-wheel or 4-wheel ABS?
Pretty sure it's 4 wheel. 2 wheel was a passing thing when ABS first made the market.
Look at the brake controller where all the tubes come out. You'll find four, one for each corner.
Or, just find some wet pavement and stand on the brakes.
I recommend doing this anyway if it's new to you, especially if it's your first ABS vehicle. Some people are surprised by the noise and feel of ABS and you don't want that surprise in conjunction with another surprise.
On my E150 '93 there should be RABS, and there is a sensor wire on the diff.
I believe that the control unit should be in front of the passengers knees, but there is only one electronic unit there, not two, as in the book.
Is it possible, that the RABS unit was simply removed by a previous owner?
Is the only consequence that there is no rear ABS, and the brake system just works as a conventional system?
Thanks,
Cor
PS: if so, is the RABS unit expensive?
Thanks,
Cor
My van has the AOD transmission, so that is not electronically controlled, I think. So this RABS might be in that case a separate stand alone unit?
There should be 2 control units according to my book, the other one is for the wiper control module. The wipers work according to plan.
RABS I have never tried out, but there is a loose connector passenger side, and only one controlunit fitted.
Further thoughts?
Cor
Further thoughts?
Cor
02-22-2007 03:10 PM
