Timing Chain Cover??????
Quick question...
What is involved in replacing the Timing Chain Cover in an 89, 5.8 Windsor FI.
I had the Water Pump replaced and the shmucks [mechanics] broke the three bolts on the top half. They had to drill em out and obviously damaged the timing chain cover cuz coolant is leaking from behind it. Just wanna know what is involved.
Not too bad. Getting to it is most of the work. Make sure you get a good seal between the bottom of the cover and the drain pan (if my memory serves me correctly). You will need a new cover gasket and the crankshaft seal. If you have high miles, you might want to consider installing a new timing chain - they stretch over time and can throw the valve timing off a little.
mike 96 ws6
08-03-2011 03:20 AM
windsorizer
03-30-2001 06:09 PM
