Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-09-2004, 10:16 AM
1978Crew 1978Crew is offline
Garage is empty, add now
1978Crew is starting off with a positive reputation.
DuraSpark with Propane
Can a duraspark ignition module be modified to work with propane? I am considering a conversion on a 78 with 351M. I am looking for the correct ignition control.
__________________
1978 F250 2WD Crew Cab 351M/ C6 - SOLD
1999 F250 2WD CC LWB 7.3L 4R100: Door Ajar light Fixed, Power Locks Fixed, Rotella T6 Synthetic, Fuel Bowl Seal Kit
  #2 (permalink)
Old 11-09-2004, 12:24 PM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
1978 Ford F-150
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
a friend of mine has a bus with FE motor, dual fuel. I don't know what ignition was used on it, but it had the propane on it. I may have to try to get a look at it sometime if noone else has an answer for you.
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto
Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
  #3 (permalink)
Old 11-09-2004, 03:17 PM
Thanks
any help is appriciated
__________________
  #4 (permalink)
Old 11-09-2004, 11:20 PM
Phinxter's Avatar
Phinxter Phinxter is offline
1992 Ford Ranger
Phinxter is gaining momentum as a positive member of FTE.Phinxter is gaining momentum as a positive member of FTE.
Cummins makes a version of it's 'B' series diesels converted to run on either CNG or LPG, and they both use Ford ignition modules. We have an old chevy 305 on a stand that was converted to propane, and it uses a stock distributor and ignition. Bi-fuel vehicles use one ignition, I don't see why you couldn't use the duraspark as is. Maybe you might widen the plug gap a bit, but I don't think you even need to do that.
Why do you want to convert anyway?
__________________
Phinxter "Have you ever worked on a Caddy?"
1992 Ford Ranger Danger 3.0 5spd 4X2
1993 Plymouth Sundance (Member of the Allpar 200k club)
2009 Saturn Aura
2004 Jeep Grand Cherokee Limited V8
  #5 (permalink)
Old 11-12-2004, 09:25 AM
Convert to propane??
One answer to the reason why is, because I want to try it. My truck is a toy for me. I hope to someday use the truck as a camper truck, but for now it is a toy I play with out at the family farm. Another reason, I would like clean up the emmision on the truck. I know I could do this with some improvements to the gasser engine, but I think it would be more costly to do so. Propane burns cleaner. I had hoped that fuel cost would be less, but have found that fuel will be about the same. I may save on some of the wear and tear on the engine with the cleaner burning fuel. For the tractor and the jeep out on the farm, when they get converted, I will be able to buy fuel without paying the state motor fuel tax, because those vehicles are not considered road use vehicles, so I will save some fuel costs. Ultimatly, the USA will need to move away from imported fuels. CNG and eventually compressed methane from organic, homegrown stocks could power our vehicles - Propane will be the first step in gasseous fuels. Am I on a soapbox, sure feels that way.....
Anyway, thank for the info about the duraspark ignition module. I have not messed with mine to adjust the timing. Something I will need to do for the conversion.
__________________
  #6 (permalink)
Old 11-12-2004, 03:15 PM
Phinxter's Avatar
1992 Ford Ranger
I agree with what you say about a need to get away from foriegn oil. I think just this week Shell Oil opened a hydrogen filling station in Washington D.C. to fill some govt hydrogen vehicles. What I would like to see more of is places to fill with E85 and Biodiesel. Here where I live they are going to build ohio's first of something like 6 ethanol plants, we have one place in the state that E85 can be bought, which sucks! Most of the Biodiesel made in this country is shipped to Europe, why aren't we using it?
I have been considering buying a VW with a diesel, and put propane injection on it for fun, but haven't been able to find really anything about doing it, mostly just trucks.
Oh well have fun, good luck!
__________________
2009 Saturn Aura
  #7 (permalink)
Old 11-12-2004, 04:31 PM
fellro86's Avatar
1978 Ford F-150
What really irks me is that I can get Biodiesel right here in my local area, but the ****** put the dye in it!!!! I can't run it on the highway legally, so what's the point?
__________________
  #8 (permalink)
Old 11-13-2004, 06:19 PM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
Quote:
When was the last time someone looked in your fuel tank?
  #9 (permalink)
Old 11-13-2004, 06:25 PM
fellro86's Avatar
1978 Ford F-150
it does happen, there are those around the area that have been tested and subsequentially busted for it...
__________________
  #10 (permalink)
Old 11-13-2004, 08:59 PM
Were they corporate drivers? Where was the reasonable cause? What, do they just pull you over for a random check?
  #11 (permalink)
Old 11-14-2004, 06:15 AM
fellro86's Avatar
1978 Ford F-150
local farmers, leaving the sale barn. On occasion, they can spot check if they feel the need to be a pain.
__________________
  #12 (permalink)
Old 11-15-2004, 01:30 AM
Phinxter's Avatar
1992 Ford Ranger
I'm in college right now and some guys from Indiana and Pa have told me they have been pulled over for a check.
__________________
2009 Saturn Aura
  #13 (permalink)
Old 11-15-2004, 12:43 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Guess how they make hydrogen? cracking it from petroleum, so there's no difference between that and gasoline in terms of relying on foreign oil...
Good luck with the propane! I don't think you need to do anything to the ignition except timing for burning propane, but I could be wrong ...
__________________
- art k. - Moderator for the Superduty, V10, 6.2L and FE forums
'13 Taurus SHO 3.5L Ecoboost w/Perf Pkg
'01 F250SD SC SB XLT V10 4x4 Volant CAI Hedman headers 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see. ®
  #14 (permalink)
Old 11-15-2004, 12:49 PM
fellro86's Avatar
1978 Ford F-150
[quote=krewat]Guess how they make hydrogen? cracking it from petroleum, so there's no difference between that and gasoline in terms of relying on foreign oil...
That's why I think the fuelcells are a loke, it won't help anything, until they can get hydrolysis to work, and then water will get to be a premium, but it's a lot easier to reform, and that would be cool, split it to recombine it, never ending circle.
__________________
  #15 (permalink)
Old 11-15-2004, 06:21 PM
archangel archangel is offline
archangel is starting off with a positive reputation.
Dye eh?
Outside of big rig truck stops checking big rigs for dye on full service fuelups,I have never seen or been told of someone in a pickup truck being checked for dye.
Is there anyone out there in a pickup that has been checked?
Tags
duraspark, propane
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
