power steering box from bronco?
Old 11-09-2004, 04:11 AM
mopower's Avatar
mopower
mopower is offline
Hi, today I stumbled across a 1979 bronco with the power steering box still attached at the local pick a part.
Anyone know if this is the same box as the 78-79 f-150 4x4 box to do the power steering conversion?It was mounted to the outside of the frame and i recall had 3 large bolts attaching it.
Old 11-09-2004, 09:56 AM
bertha66's Avatar
bertha66
bertha66 is offline
Yes, I do believe that is the box that alot af people use, what does the yard what for it? Most of the Bronce places ask a high price.
Old 11-09-2004, 11:36 AM
mopower's Avatar
mopower
mopower is offline
The price is whatever pick and pull gets, I think a steering box is $25
I am going to go back today and get it for my core.
To bad the complete front axle is gone, would have been a nice easy disk brake conversion.
Thanks.
Old 11-09-2004, 12:02 PM
RR4E's Avatar
RR4E
RR4E is offline
Thanks.
I did that exact conversion on my 69 F100 4x4. I was lucky, and came accross a whole donor Bronco(1979) for 500 bucks. I also ended up with it's version of the NP435 4 speed trans, and 2 speed transfer case, took it's front end for the disc brakes(proportioning valve, master cylinder, etc) the intermittent windshield wiper switch and delay box, and the tilt steering column. All the way around, it made for a very nice truck to drive afterwards.
Old 12-11-2004, 02:31 PM
The67Beast's Avatar
The67Beast
The67Beast is offline
Hey "RR4E" I have a 67 F-100 4X4 and would like to do the same conversion on my truck. I have a 79 Bronco P/S gearbox, but not sure of what all i need to do to get it to work. How did you get it to fit without it hitting the radiator support? Also, the 79 box that I have is reverse rotation from my stock manual box. Did you have it reworked to turn a different way? Also what other parts did you use, and where did they come from. Any advise at all will be appreciated very very much.
The 67 Beast
Old 12-11-2004, 09:24 PM
baitmaster's Avatar
baitmaster
baitmaster is offline
ps info/buyer beware
Just replaced today the ps box on my '72 4 wheeler. I had bought the ps kit from the guy in Iowa, and I suspect he sent me used parts with a new paint job. The ps pump sounded like it was full of gravel, and the box developed a leak after 1 month, and had so much play in it, I had to tighten it up til it wouldnt return to center. He reimbursed me for the pump, but now I got to write him about the box. Anyhow a rebuild box was 170, with a $50 core. The box is the 2 wheel drive '77 ford truck. (3 bolt). If someone wants the complete set of instructions on how to do this project e mail me and I will send them.
Old 12-13-2004, 12:28 AM
Nod's Avatar
Nod
Nod is offline
Power Steering Conversion
The 67 Beast,look in the Technical Articles under Steering and Suspension,there is an article there on how to power steer a 67-72 F-100 4x4.Have fun.
"bowties in the rearview mirror"
Pokee
03-29-2017 04:12 AM
Schuyles
04-08-2016 09:00 PM
mr56effie
07-25-2014 07:18 PM
maverick600
01-06-2014 12:11 AM
marriedguy1
1978 - 1996 Big Bronco
05-26-2001 07:29 PM
Quick Reply: power steering box from bronco?
