Points to electronic ignition.
I'll back tbird's recommendation there. The pertronix is a true bolt on kit, no need to change the distributor(unless it's worn out). http://www.pertronix.com/ You can choose from the Ignitor or Ignitor II kit, the latter being a bit more performance oriented.
Use a GM 4 pin module with your points. They will never burn up again.
Use a GM 4 pin module with a Duraspark II distributer.
Use a GM 4 pin module and you don't need an $80 box. Who buys an $80 box?
Use a GM 4 pin module or buy an MSD box. I detest Pertronix.
Use a GM 4 pin module because it is cheap and works as well as more expensive options. Good to about 400 HP they say.
I think there is a tech article on this site about using the GM Module.
Pssssst.......Hey buddy.........I use GM alternators on all of my Fords too!
Some of us won't desecrate a perfectly good truck with GM parts....although I've seen it done.
Since KC brought up the MSD...I have an MSD 6AL and an MSD TFI Blaster coil that I originally purchased for my TFI Bronco. I'd like to use it on my '77 F250 which still has the oem Duraspark. Will the 6AL eliminate the Duraspark module or must I retain the factory module as is necessary on TFI eqipped vehicles? (necessary owing to the lack of a trigger on TFI distributors as opposed to the Duraspark distributors which are equipped with a trigger). I have an Accel Super Coil (#140001) which I could use instead of the Blaster coil. Any suggestions on which coil/module to use?
I changed my 360 over to a dura-spark system because i had the spare parts layin around, only needed a distributer out of a '76 & up (besides my old dizzy was worn out). It works perfect but if I had not had the stuff I would have gone with a pertronix with out any hestation. P.S. puttin gm parts on a ford is like puttin lipstick on a man.... It dosent belong and people will never look at you the same again
You know what? I am always willing to help when I can! Sorry it is so large. If it gets removed PM me and I'll email it to you.
Originally Posted by docholiday72tx
I love it!!!! I couldn't have said it better my self. I'm not sure about the rest of ya'll, but GM parts won't fit my Ford no matter what you do to it. That guy sounds like the type that would take a perfectly good 36 coupe, and ruin it with a 350 engine and turbo 350 transmission. There are a multitude of actual Ford and aftermarket parts that you can use with out going to the General.
It is cheap, easy, looks cleaner and works better. I would never put a SBC in a 32 Ford. In fact I don't like cars. I wouldn't put a SBC in a Ford truck either.
BTW, I have never purchased a GM module MADE by GM. GM doesn't make 'em. The same folks who make your Duraspark box make 'em.
Tell me which looks better and cleaner:
This?
Or this?
There are lots of Ford guys who have been doing this Mod for years. That is what it is, a modification.
I've got a 90 Amp ALT in my Bronco II and it cost me $48 and it took me 60 minutes to do it. It works good and it is cheap. Not to mention I threw away 15 feet of 20 year old wiring.
I'll bet you are real young. Take some advice from an old man. I'm just trying to help ya' and that is no reason to insult me.
BTW, I have a very strong and very long background in electronics.
Kc. In the first place. I am very sorry. I had no intention of insulting anyone. That guy with the lip stick remark just had me floored I was laughing so hard. In the second place, I" ve been around the block a time or two, and am no where near young. How ever I do wish very much that I was. Now as for your 3 pictures up there: The first is a good upgrade. I added the Msd module to my truck, and it starts up like it's fuel injected. The second picture is what I assume is a diagram to change from points to duraspark with the factory ignition module. Sorry, when I origionaly did that to my truck, it was no where near that complicated. The third picture, I'm assuming is adding the general's coil. I don't understand the diagaram. What do the G,W,B,and C represent? The curiosity is killing me. I always like learning new things, and the best things come from the older generation. Last but not least, what did you gain by going from the ford alternator over to G.M. other than doing away with some old wiring? Once, again the curiosty is gettin to me. Once again, let me apolojize for insulting you.
