94 B2300/Ranger Gas Gauge
Old 08-19-1999, 10:33 AM
Will Brown
Guest
Posts: n/a
Any known problems with '94 Ranger/B2300 gas gauges? I just got a '94 B2300, and gas gauge reads empty with the key ON, and about 1/4 tank with the key OFF. Was told by previous owner it occasionally works, but I've never seen it work. Am starting to procure manuals and dig around the truck myself, but don't want to re-solve the problem if it's a known one. Haven't seen mention on the net of it being a recurring problem, but just starting to dig...
Thanks,
Will
Old 07-06-2002, 10:53 PM
davvet2's Avatar
davvet2
davvet2 is offline
Had the same problem with mine, ended up being a faulty fuel sender.
Unfortunately, I had to buy the fuel pump/sending unit combination, cost $120.00 at O'Reilly Auto Parts, and $95.00 labor to install it.
You'll either have to remove the bed or use an overhead lift to install it.
Good Luck !
Jim
Old 07-08-2002, 09:37 AM
Rand's Avatar
Rand
Rand is offline
[updated:LAST EDITED ON 08-Jul-02 AT 10:38 AM (EST)]On my thunderbird the fuel gauge was wacked and it had a bad ground.
thats after they quoted me 4 hours labor to drop the tank + parts
took me 5 min to find the missing ground
It might be that simple.. then again you might need to replace the fuel sending unit which is what I thought MY problem was.
Rand
BTW you dont have to remove the bed you could drop the tank.. its
just much easier to remove the bed susposedly. Since I have never removed the bed on my ranger I couldn't tell ya but i know its a real be-itch to drop a tank.
Old 07-09-2002, 09:26 AM
adkinsca's Avatar
adkinsca
adkinsca is offline
[updated:LAST EDITED ON 09-Jul-02 AT 10:29 AM (EST)]I would suspect a bad fuel level sender as well. I don't have any experience with this on a Ranger/B2300, but with an 1989 Ford Mustang.
I dropped the gas tank at least 3 times on that car, and it wasn't that big a deal.
Like Rand, I also don't know how hard removal of the bed would be on the truck, but I would think that the tank would be easier. After all, how much does the bed weigh? It certainly doesn't seem like a one man job unless you have some kind of lift. The tank is easily a one man job, just run it pretty low on gas before you try to remove it.
Old 07-09-2002, 01:22 PM
Ken00's Avatar
Ken00
Ken00 is offline
Old 05-31-2012, 10:31 AM
Sylvie's Avatar
Sylvie
Sylvie is offline
My newly acquired 1989 Ranger has a gas gauge always reads full and the temp gauge always reads C. Sounds like I need new sensors.
Old 05-31-2012, 01:04 PM
reddog99's Avatar
reddog99
reddog99 is offline
Be sure to check all the grounds, including behind the instrument panel. A bad ground was a known cause of instrument malfunctions.
rebnutt
10-25-2016 01:29 PM
eygore
01-02-2016 06:35 AM
oldschool-f150
09-03-2015 11:55 AM
amdriven2liv
04-27-2015 08:17 PM
glenT
03-25-2014 09:06 PM
Quick Reply: 94 B2300/Ranger Gas Gauge
