tired of running bad
have a 5.0l engine with E04d(?) trans. i am tired of the efi engine. always seems like somethingis wrong with the cpu/engine. always putting on the scope. cant river run cause ecu is too low and might get wet. ok enough banter.....can anyone give me a list of everything needed to swap this efi engine with a carbed engine. obviously the engine and modules but i mean good info. like will the trans hook up because its hooked into the ecu. what about fuel delivery,or will it bolt in to the engine mounts, throttle linkage an issue? i was thinking about going with a 351 windser or maybe a 360 or 390. any help would be greatly appreciated. this is the second 5.0l in this truck and i would like this engine swap be the last!!!!
