Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 11-06-2004, 07:27 PM
87f150xlt 87f150xlt is offline
Garage is empty, add now
87f150xlt is starting off with a positive reputation.
87-91 Ignition switch replacement,
After some research I came to find out that Ford offers revised Ignition switch for 87-91 F series/Bronco.
I replaced the ignition switch with hope to resolve "hard to or not starting when warm" problem on 87 F150, didn't resolve the problem but nice to have improved switch installed. Original design is known to cause connection problem and in some cases fire, some articles can be pulled up from search engines under "Ford ignition switch".
Dealers will try to sell you original old design if you don't ask for the right part number. Ask for SW-2472 or F2TZ-11572-E, actual part came in the box was stamped F2TA11572EA This means it's Revision EA. Original switch came on my truck reads E7TA-11572-AA this means it's Revision AA(the old skool original faulty design!).
Advanced auto parts wanted almost $12 for aftermarket unit, dealer wanted $16.60 for original faulty design switch and only $13.28(list price) for revised SW-2472. I called around for this part number and some dealers knew and some didn't know about design change. I bought mine from Burd Ford in Indianapols, didn't have one in stock but got one for me in an hour even on Saturday!.
  #2 (permalink)
Old 11-06-2004, 08:54 PM
jrmahan jrmahan is offline
jrmahan is starting off with a positive reputation.
Our shop buys ignition locks for Auto Security Products (ASP) 87 used a 10 cut key which is needed to remove old lock to replace with a new lock.
I imagine you are talking about the switch bolted to the column that the pushrod engages to start the engine. I replaced mine with one from AutoZone - worked fine.
  #3 (permalink)
Old 11-07-2004, 12:35 AM
yes, this is Ignition switch. not the Key cylinder.
Tags
87, 8791, chang, e7ta11572aa, f250, f2ta11572ea, f350, ford, ignition, part, pickup, removal, switch, truck, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
