Go Back   Ford Truck Enthusiasts Forums > Misc. > Brakes, Steering, Suspension, Tires, & Wheels
New! Use your Facebook to securely log into this site, click logo to login
Brakes, Steering, Suspension, Tires, & Wheels Click Here
Is F-150 Still King?
  #1 (permalink)
Old 11-06-2004, 05:25 PM
Brian794x4 Brian794x4 is offline
Brian794x4 is starting off with a positive reputation.
How to measure wheel offset?
Hey guys, i posted before about finding some 15x10 ford steel wheels at a wrecker. I want to see what kind of offset they have so i can see if they'll work for my truck with the lift. Is there a method with a tape and strait edge or anything?
And on a side note, my 79 150 4x4 is lifted 6" and ill have a body lift... how much of offset will i most likely need? Ill be putting 38x15 wide tires on it in the spring, and probably flares i think too, if that helps. Thanks alot for any help!
Brian
  #2 (permalink)
Old 11-06-2004, 06:42 PM
SoCalDesertRider SoCalDesertRider is offline
SoCalDesertRider is gaining momentum as a positive member of FTE.
lay the wheel down face-down and put the straight edge accross the wheel lip and measure the depth to the inside of the wheel mounting surface, where the lug holes are.
__________________
Thanks, SoCal.
69 Bronco 302 & 92 F350 CrewCab 4x4 haulin' SixPac slide-in camper.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive -
Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
