lean code 01 5.4????
I am working on an 01 expedition with the 5.4. My buddy drove through deep water and filled a couple of plug wells with water. I had codes for misfire cyl 2, 4 and lean on bank one. I replaced the fuel filter and cleaned the plug wells and boots and put a bunch of dielectric grease on everything.
That fixed the misfire code but the lean code (bank 1) came back. The only driveability issue is a slight hesitation or chuggle at low rpm in overdrive. Does anyone here have experience with this problem?
Thanks in advance, David
Sniper_Clown
02-23-2011 08:59 PM
