What lube for slip yolk? - Ford Truck Enthusiasts Forums
Old 11-06-2004, 07:51 AM
Lesspaul's Avatar
Lesspaul Lesspaul is offline
Lesspaul is starting off with a positive reputation.
What should I use to lube my slip yolk? I'm thinking wheel bearing grease.
Old 11-06-2004, 07:56 AM
holland501 holland501 is offline
holland501 is starting off with a positive reputation.
Absolutely correct.
Old 11-06-2004, 08:18 AM
Lesspaul's Avatar
Thank you, I will begin the task with confidence knowing I am doing it right instead of guessing.
Old 11-06-2004, 01:42 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
Here's another possiblity:
http://www.ford-trucks.com/forums/sh...d.php?t=266696
In addition, teflon-based greases are also recommended highly by many Ford Techs for lubing slip yokes.
Old 11-06-2004, 02:54 PM
Steina Steina is offline
CO River Rat
Steina is gaining momentum as a positive member of FTE.Steina is gaining momentum as a positive member of FTE.
Sta-Lube makes an extreme-pressure moly grease suitable for slip yoke splines.
Steve
Tags
2001, 73, f150, ford, grease, lube, lubing, moly, slip, sta, yoke, yolk
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
