Bed Liners, Drop in Or Spray On
Go with ANY name brand spray on - doesn't create the rust problems the drop in does. Just make sure it covers the inside of the bed completely - even under the rails..
The drop in work fine, but when you get dirt and water under it - and you will no matter how well you take care of it - it sands the paint right off and then rusts!
I also used the herculiner in my truck. Its a do-it-yourself roll on bed liner. I picked up a can of it at autozone. When I got my truck it had a drop in bed liner. When I pulled it out my paint was in bad shape. I also had surface rust starting.
The Herculiner did okay, It takes quit a while to apply and I don't think I put mine on thick enough. After about a year and a half of good use I've worn a lot of it off. It was, however, cheap and prevented any rusting.
I've seen some trucks with line-x and that stuff seems to hold up real good. It's put on pretty thick too.
The best products are a spray on bedliner. We suggest going with a High Pressure (Hot Spray) system and staying away from teh colors other than Black. The makers of HP are Ultimate Linings, Line-x and a little w/ Rhino. The best product is definently the ones sprayed by independent businesses. Often times they even purchase products from us to get better quality than the franchizes. http://www.sprayonbedlinersdirect.com
Originally Posted by macmac
The best products are a spray on bedliner. We suggest going with a High Pressure (Hot Spray) system and staying away from teh colors other than Black. The makers of HP are Ultimate Linings, Line-x and a little w/ Rhino. <snip spammage>
LINE-X and Rhino differ quite a bit. The biggest difference is that LINE-X contains polyurea and Rhino does not. Polyurea enhances the bedliner’s properties: 1. LINE-X's temperature tolerance is 250 degrees and Rhino's is 175. As the temperature of the bed approaches the temp tolerance, it loses its strength. 2. Polyurea keeps moisture out of the solution thus making a more dense and solid liner. Less moisture also means better adhesion. 3. Polyurea also makes for a harder liner. The tear strength of LINE-X is 304 pounds per linear inch (pli). Rhino is 145 pli. 4. Polyurea sets up very fast, that's one reason why LINE-X goes on with heat and high pressure. LINE-X dries in about 4 seconds, so you get an even application throughout the bed. Rhino takes a minute or so to even gel, an hour or so to dry. Before it gels, gravity can pull the liner from the top ridges in to the low valleys. Rhino’s Tuff Stuff goes on cold/low pressure and thus has that “cottage cheese” or “rain on the windshield” look. LINE-X’s high heat/high pressure system gives it a very nice finished and more consistently applied texture, it’s sort of like an orange peel. The dealer can vary the texture from smooth to very rough. 5. Polyurea makes the liner more chemical resistant, especially to organic oils and solvents.
LINE-X is the only brand with a NATIONWIDE lifetime warranty. Rhino's warranty is only with the dealer that sprayed it.
Here is a bit of history: First on the scene were epoxy based products. They were not very durable, they cracked, peeled, etc. Then, ONE-part polyurethane products came along. One-part means that the polyurethane is suspended in a solvent. A catalyst is added which starts a chemical reaction that removes the solvent so that you have just polyurethane left. They were a significant improvement over epoxy based products. Examples of today’s one-part polyurethanes include Herculiner, Duplicolor, Durabak, and Speedliner. The newest technology is TWO-part polyurethanes. Two-part means that a resin (usually a polyol resin) is mixed with isocyanate (a hardener) which renders the polyurethane. Two-part polyurethanes are harder and much more durable than one-part polyurethanes. Two-part polys are used on today’s boats, airplanes, etc. Examples of today’s products that have two-part polyurethanes include LINE-X and Rhino.
Most brands just add pigment to color the liner. Pigmented liners will fade. Most LINE-X dealers also use Dupont Nason paint. Nason paint is an automotive paint and will not fade. If you get a color match, be sure they use Nason paint as well as pigment.
Hope that helps!
Hope that helps!
When I started reading this thread I knew that the hard finish, fine grained Line-X finish looks a lot better than the "chunky peanut butter" finish from Rhino and that I have seen colored liners fade atrociously ... red into a very sickly pink Total agreement with macmac
We recommend and sell Line-X at the dealership where I work. We had our own for a while but went back to the Line-X sublet. The product is superior, now I even understand why ... Thanks TruckDaddy!
Originally Posted by ASHES
LINE-X using low quality polyurea? Let me be bold and say you don't know what your talking about. Raw materials are purchased from BASF Corporation. You tell me what company in the W O R L D has better quality than BASF. http://www.basf.com/static/index.html
By the way, I'm a LINE-X dealer and you sell no name bedliner products. There are VERY few companies that actually manufacture the raw materials, where does yours come from? I know you don't manufacture it, so who do you buy it from?
