Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Closed Thread This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 11-04-2004, 08:38 PM
IB_Tim's Avatar
Administrator
IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.IB_Tim has a spectacular reputation.
..................Tech Folder..............
TECH FOLDER
Check back...we update often
EGR Disconnect Instructions
EGR Disconnect Instructions - Ford Truck Enthusiasts Forums
And Cleaning
Scary pics of my 11,000 mile-old EGR valve - Ford Truck Enthusiasts Forums
Brought to you buy t_b
6.0 fix for various running problems
6.0 fix for various running problems...Must Read! - Ford Truck Enthusiasts Forums
Crankcase Ventilation Rerouting
Crankcase Ventilation Rerouting - Ford Truck Enthusiasts Forums
Intercooler hose clamp
Intercooler hose clamp - Ford Truck Enthusiasts Forums
Powerstroke 6.0 L Technical Intro Manual
Powerstroke 6.0L Technical Intro Manual
or
6.0L Bible Table of Contents
'05 PSD Update to Powerstroke 6.0 L Technical Intro Manual
2005 6.0L Bible Update Table of Contents
Super Duty FAQ
Super Duty FAQ's
6.0 in very cold climate
Newbie considering 6.0 in cold climate - Ford Truck Enthusiasts Forums
Powerstroke diagnostic trouble codes
Ford OBDII Diagnostic Trouble Codes - Powerstroke Diesel Codes .: Articles
Body Builders Guide - includes PTO, snowplows, body sizes etc.
http://www.ford-trucks.com/tsb/fulltext/index.php
__________________________________________________ ____________
Small Hint For Flash Programmer
UsersSmall Hint For Flash Programmer Users - Ford Truck Enthusiasts Forums
Thanks Matt
Controller Area Network Explained
Controller Area Network Explained - Ford Truck Enthusiasts Forums
and again thanks Matt
High Idle Mod
http://dan.prxy.org/Truck/Other/High_Idle/High_idle_mod.html
Thank you hitecdan
Instructions for changing your filter (Fuel):
FUEL/WATER SEPARATOR DRAIN PROCEDURE
Thank you SBV45…
And changing filter (Air)
Thank you SBV45…
And changing oil
CHANGING ENGINE OIL
Thank you SBV45…
And Fuel/Water Separator Drain Procedure
Thank you SBV45…
Battery Disconnect —Dual
Battery Disconnect - Dual
Thank you SBV45…
Torqushift Shift Relearning Strategy
Thank you SBV45…
How to Harpoon the fuel tank
Harpoon The Tank? - Ford Truck Enthusiasts Forums
Thank you Bob
What does each Flash do
http://www.flatratetech.com/6literpowerstroke/cal_updates.html
Engine Break in
breaking in the 6.0L - Ford Truck Enthusiasts Forums
Tow/Haul mode on start-up mod
TOW/HAUL- any way to set as start up default??? - Page 3 - Ford Truck Enthusiasts Forums
Thank you me1mckee...
Mirror Swap
'03 Mirror Swap - All Done! - Ford Truck Enthusiasts Forums
Thanks to Rick "Karic"...
UpFitter Switch wiring
http://www.fleet.ford.com/truckbbas/non-html/Q117.pdf
2005 upfitter realy panel location?????? - Ford Truck Enthusiasts Forums
Engine Idle Control
Engine Idle Control - Page 6 - Ford Truck Enthusiasts Forums
Thank you me1mckee and JimReitz...
Things to know about towing
https://www.fleet.ford.com/showroom/rv_trailer_towing/2005/2005_weights.pdf
Processor Code Location
Processor ID Code - Ford Truck Enthusiasts Forums
Thanks Maxium 4x4
Missing Items on the Super Duty
Missing Items on the Super Duty - Ford Truck Enthusiasts Forums
Thank you 04FordHarleyF250
Tractive Force graph
Tractive force graph (contains photos) - Ford Truck Enthusiasts Forums
Thanks to me
2002/2005 F-250/350 Proper Foglight Operation/ SUVLIGHTS Harness Fix
http://www.ssdiv.com/fogfix.html
Thanks to big ride and 4X4 IN REFUGIO
EGR O-Ring Ford Part Number
Egr-o Ring Ford Part# Is - Ford Truck Enthusiasts Forums
Thanks to eight301
Block heater cord routing
http://www.forddoctorsdts.com/articles/article-05-20.php
Cord part number at International: Z3500043
Ball Joint replacement
How to replace your Super Duty Ball Joints - Ford Truck Enthusiasts Forums
Thanks to RacerGuy
Transfer Case, Power Steering, Differential Oil
Additional Maintenance not addressed in Tech - Ford Truck Enthusiasts Forums
Thanks to Bear Hunter
Elimination of Door Chime
Elimination of Door Chime - Ford Truck Enthusiasts Forums
Thanks to kb1aah
MPH Speedo Calculator For Variable Tire Sizes
Speedometer Calibration Calculator And Information
__________________________________________________ ______________
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-04-2006, 12:01 AM
kw5413's Avatar
Signed, sealed, delivered
kw5413 has much to be proud ofkw5413 has much to be proud ofkw5413 has much to be proud ofkw5413 has much to be proud ofkw5413 has much to be proud ofkw5413 has much to be proud ofkw5413 has much to be proud ofkw5413 has much to be proud ofkw5413 has much to be proud ofkw5413 has much to be proud of
Always bright overhead display: http://www.billgart.com/l.html#alwaysbright
Thanks for the find Customz
Greasing the driveshaft slip joint: http://www.eurekaboy.com/f250/slipjoint.htm
Thanks again to Customz
Fuel Gauge (Gage) / Level - Read post # 7
Gas Guage - Ford Truck Enthusiasts Forums
Thanks to Hayapower!
Reprogramming "Flash" Procedure For Techs
Hey kw.... - Ford Truck Enthusiasts Forums Post # 13
Thanks vloney & huntercgr
Transmission Flush Proceedure...Great "How To" Article
http://www.truckblog.com/story-582-how_to_flush_fords_torqueshift_transmission
6.0 Updates from Various Model Years
http://www.ford-trucks.com/forums/52...ml#post3974497
Great Lie-O-Meter Explaination Post # 2
http://www.ford-trucks.com/forums/53...ml#post3990543
Thanks Matt.
Resident Diesel Technicians
http://www.ford-trucks.com/forums/52...ml#post3998872
CJ4 rated oil, from API...See Post # 19
http://www.ford-trucks.com/forums/53...ml#post4014847
Special Thanks To mrxlh
OEM Oil and Fuel Filters... What To Look For
http://www.ford-trucks.com/forums/54...ml#post4145955
Thanks to Beachbumcook...Great research.
__________________________________________________ _________________
Transfer Case Fluid change
http://www.guzzle.rbmicro.com/transfer.html
Thanks to Customz for finding
SRW rear differential fluid change
http://www.guzzle.rbmicro.com/rdiff.html
Front differential fluid change
http://www.guzzle.rbmicro.com/fdiff.html
Replacement brake rotors and pads
http://www.guzzle.rbmicro.com/pshawk.html
Changing Injectors
http://www.ford-trucks.com/forums/57...ml#post4355612
Thanks to Matt
Fabricated Aux. Fuel Tank
http://www.ford-trucks.com/forums/58...lly-sorry.html
Thanks to bczolone...Nice Work!
Tips to prevent common probelms
http://www.ford-trucks.com/forums/70...-problems.html
Thanks to bismic
Workshop manuals 1996 to 2008
Ford Truck Enthusiasts Forums - View Single Post - Links to the online Superduty workshop manuals
Thanks to PowerstrokeHD and Ozx3+1
__________________
"Life is tough, but it's tougher when you're stupid."
Closed Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
