Michigan Chapter Join Chapter, Leader: Toyman
Explorer Lower Ball Joint replacement.
Old 10-02-2004, 03:16 PM
Neumech's Avatar
Neumech
Neumech is offline
Question Explorer Lower Ball Joint replacement.
Being a relatively low skilled wrench, I would appreciate any help. I need to replace lower ball joints on a 2000 4x4 Explorer. Are any special tools required to perform this work, which includes removal and replacement of the lower control arm and torsion bar. I have to do this in my garage and am a little leary of the torsion bar issue. Any suggestions about procedure? Thanks.
Old 12-03-2004, 08:31 PM
countrymike's Avatar
countrymike
countrymike is offline
rent a BALL JOINT PRESS i found them at autozone
Old 12-15-2004, 04:20 PM
92nite's Avatar
92nite
92nite is offline
it is possible to do it without completely removing the lower control arm but you do need a ball joint press also is it 2wd or 4wd
fred_79f250
1997-2006 Expedition & Navigator
08-17-2014 12:26 PM
shootr19
1997 - 2003 F150
02-23-2012 09:08 PM
jimwesselman
1997 - 2003 F150
04-16-2008 02:56 PM
03redranger
1983 - 2012 Ranger & B-Series
02-22-2007 04:28 AM
rmroost
12-15-2004 07:24 PM
Quick Reply: Explorer Lower Ball Joint replacement.
