EGT gauge
If it is cold, after sitting over night, you can drill in about an 1/8 of an inch, then start the truck let it idle and drill the rest of the way through.....turn it off and finish the job.
Tapping can be done in quarter turn increments, then back out the tap and do the same again...this will keep the chips out of the exhaust manifold.
Did yo get your gauges from MotorHaven
Originally Posted by mikey_d66
I hate to make this process harder than it needs to be but wouldn't it be a good idea to take the manifold off? I'm probably being paranoid but it really wouldn't take many shavings to ruin a turbine.
on
So many folks have done install with the manifold still on the truck and not had any problems that I think you can do it just fine if you are careful.
If you are mechanically inclined and don't mind doing the extra work, and feel more comfortable with the added piece of mind you will have by removing the manifold and doing it off the truck, then go for it.
I removed mine and it wasn't that bad of a job, but now that I've held the manifold in my hand and know right where to drill and tap, if I were to do another one, I'd probably leave the manifold on the truck and do it that way.
