Check Engine Light on 88 Ranger 2.9L (Code 61 - ECT) - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 07-25-2002, 07:22 AM
superrangerman2002's Avatar
superrangerman2002 superrangerman2002 is offline
superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.
Old 08-01-2002, 05:56 PM
crb3 crb3 is offline
crb3 is starting off with a positive reputation.
Post Check Engine Light on 88 Ranger 2.9L (Code 61 - ECT)
I have an 88 Ranger 2.9L, Automatic, 150K miles that has the CEL on while driving now. I will start from the beginning:
Last week the truck started idling rough and stalling at lights if I had the AC on. I changed the plugs, rotor, cap, wires, air filter, pvc, and breather to no effect.
On Tuesday it stalled several times on the way home from work. Everytime it dropped to idle it would stall whether the AC was on or not. At this time the CEL came on and stayed on. I checked the codes and got the following:
61 - ECT indicated 254 F/grounded circuit
After seeing the codes, I replaced the ECT with a new one. I then reset the computer. When I started the truck I got a CEL along with the same code.
I knew it would not solve the problem, but at the advice of a friend I used Intake Cleaner on the throttle plate. It helped some. The CEL light still comes on with the same error, but now the truck will idle.
To the point - any idea what to try next for the code 61? Since the new part did not fix it I was assuming that there could be a ground in the circuit, but I dont have a clue how to start diagnosing where it might be.
Any ideas?
Thanks
Rick
Old 08-01-2002, 06:54 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
Rick,
You should run the pinpoint tests, these determine the exact cause of the code. It sounds like you have a wiring problem, do you have a meter? I can send the tests to you from my 1988 Ford manual, send me an email with your email, remind me of what you need.
Ken
Old 08-02-2002, 12:39 PM
Ken00's Avatar
Check your mail.
Old 08-02-2002, 05:24 PM
I recieved the Tests. I will try them out over the weekend and let you know how it turns out.
Thanks!!!
Rick
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 03:27 PM
Can someone explain this to me? 1987 - 1996 F150 & Larger F-Series Trucks 11 03-09-2016 12:40 PM
ooops Aerostar 5 01-14-2015 03:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 06:14 AM
DPSE Roachfood 1987 - 1996 F150 & Larger F-Series Trucks 3 03-11-2002 10:21 PM
Tags
1988, 29, 88, check, circuit, codes, diagnos, ect, engine, ford, light, ranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
