Yes, they will. Just make sure you've disconnected all the wires and such. Mark where each wire connects to the harness to speed up reinstallation. Removing the hood and tranny crossmember will help also. You will leak ATF out of the tranny tailshaft, so cover the ground or stop up the tailshaft.
