Degree shims and junk like that
So apparently I need to point my friggin front pinion up a bit. My question is what is the verdict on degree shims? I'm not too fond of the idea but what do I know . . . I've got a . . . nevermind. Seems to me that degree shims up front aren't a whole lot dofferent then front lift blockls. Except that they're uneven and look like a cheese wedge. But we all know front blocks are a no-no.
Pro, what would you think about just grinding an angle into those anti wrap bars instead? If I tookl a 1/4 inch out of them, angles where the back of the spring perch sits it would turn my pinion up a bit without needing those shims. I don't like the idea of the bar, shims and springs all under there . . . something is going to break in a bad way. What do ya'll thinjk?
3* should be about perfect for that....maybe, just maybe 4* but doubtful, remember on the front that chunk wants to twist down instead of up so if you shim it just a hair above when your axle is under the most stress (when taking off at first) the u-joints will be in perfect line with the driveline
-cutts-
-cutts-
What about your caster? it does not take much change in angle to cause problems,
No matter what you do it's going to be alot of work, if you turn the housing or the knuckles you will still have to use a shim on the pumpkin side, as far as angled shims go you could get some that have a small enough hole in the center to bolt it to your spring pack with the center bolt,
another thought, build longer spring hangers for the front and/or shorten the shackles on the rear (of the front springs), that would bring your pinion angle up,
Pro's truck is pre 77' so he has the devorce mount T-case,
Ivan you should keep you eye out for a devorce mount t-case, then you can eliminate your carrier bearing and have the same lenght drivelines front & rear, it would also cure you drivline angle problem, the only down side would be you would also have to come up with a different output shaft and tail housing,
