1993 ranger suspension help
i found a cracked crossmember where the radius arm bolts onto. where car i find a new crossmember ? left side . part # or web site
also my 93 ranger 4x4 xlt sits lower in the front, what can i do to lift it up to rear height ? no lift kit on my truck and front looks 2 inches lower . why ?
mine sits way high in the back also. i have a heavier rated spring pack from the factory, think it is a 5040 gvwr weight rating. i removed the rear lift blocks to level it out, didnt look bad but i ended up putting them back in due to trailer hitch height. you could get taller front springs from j.c. whitney to level it out.
