Trying to ID a holley Carb.. - Ford Truck Enthusiasts Forums
Old 11-03-2004, 01:33 PM
300six1990 300six1990 is offline
300six1990 is starting off with a positive reputation.
Question Trying to ID a holley Carb..
I'm having a little trouble with a holley carb... Someone gave me this carb a while ago, they had no idea what it came off of... I don't think it's an o.e. carb for anything because it has a manual choke and 2 fuel feeds.. I posted a bunch of pics in my gallery... Thanks in advance for your help..
http://www.ford-trucks.com/user_gall...?userid=215298
Old 11-03-2004, 07:33 PM
Mike G Mike G is offline
Mike G is starting off with a positive reputation.
Looks like an older double pumper. Check here for your numbers to see if you come up with anything... http://www.mortec.com/carbs.htm
--Mike
Old 11-03-2004, 08:22 PM
rangerboy21's Avatar
rangerboy21 rangerboy21 is offline
rangerboy21 is starting off with a positive reputation.
Try this link.
http://www.holley.com/HiOctn/TechSer...Info/4011.html
The one shown looks exactly like yours with the exception of the auto choke.
Old 11-03-2004, 08:43 PM
Great that was exactly what I was looking for , the exploded view looks like a vacuum secondary unit but other than that it's exactly the same... now I just need to find an adapter to put it on a spreadbore intake... Thanks again for the help
Old 11-03-2004, 11:35 PM
wldcat65 wldcat65 is offline
wldcat65 is starting off with a positive reputation.
It looks like it might be a 4010 750 cfm
Old 11-04-2004, 12:36 AM
Old 11-04-2004, 12:56 AM
well, it's actually a 4013 but it's the same as the 4010 and the 4011 for the rebuild kit at least.... I noticed the picture of the 4010 shows the vacuum secondaries even though the part number that holley shows is for a mechanical... from what I found on holley's website it's a universal 750 cfm double pumper with a standard square bore mount.. no info as to how old it could be... I don't think it's too old because it uses torx screws to hold everything together versus regular slotted screws like the real old ones.... I think I'm going to bolt it on and see how well it works (IF it works) before I go get a rebuild kit or anything...
What have you done to your truck today? StealthWyvern 1987 - 1996 F150 & Larger F-Series Trucks 18868 Today 04:32 PM
Body work ideas 4tl8ford 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 11-07-2015 09:20 PM
02/19/2012 Ride of the Week! glruff Ride Of The Week 9 10-24-2014 11:47 PM
8/10/14 Ride of the week fabmandelux Ride Of The Week 20 09-03-2014 06:04 PM
Seat bases that I've started 56panelford 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 08-28-2014 10:52 PM
Tags
239, 3406, 4010, 4011, 4013, carb, carburator, carburetor, diagram, engine, ford, holley, identification, model, pics, specs, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
