Thank for anyone that can help. Its a 6.0 it is very hard to start in the morning alot of black smoke takes about 20 min. to get it to start but after it warms up it cranks up fine.and I took it to the dealer and they told me it was the maf sen. replace it but it stills do the same thing but the tech said it threw codes po113,po0261,po267,po264,po270,po611,po273,po279,p o276,po282 then ran pin point and found maf sen. circuit open and what is a ficm thanks.
For the 7.3 guys it is the 6.0L version of the IDM.
The help you need is most likely a new FICM. Do not buy one off of Ebay. You get them at the dealership (some folks have talked International into selling them one).
There is a diesel place that says they can repair FICM's for less than half price of a remanufactured one (there are no more new ones). The name is SWAMPS.
__________________ Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20; DieselSite Coolant Filter; High Idle Mod; HFCM Plug; Zoodad/Air Fury grill; Accufab Elbow; RACCCV6000 filter; JimmiJammers; Ravelco; SynchroMax in Transfer Case; Fumoto Valve; Harpooned fuel tank; Line-X; CPOhighway Products tool box; tracrac; Fox Weatherboots; Wet Okole Seat Covers; Stanadyne Performance & B2 for lubricity; PIE adapter (thanks Sarge); PIAA 24" wiper blades; updated EGR valve; BriteBox; Re-flashed; Fuel Pressure gauge; DashDaq on deck
That's a lot of codes. Most are injector issues. I'm surprised it runs right. You may have an FICM harness problem.
There was a recall on some '04 models due to FICM wiring harness chafing issues. If your truck has not had Recall 05S34, read this to see if yours might have been affected:
