Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #46 (permalink)
Old 07-08-2007, 10:49 AM
JamCracker JamCracker is offline
JamCracker is starting off with a positive reputation.
Thanks Brickie, is "6.0 Bible" the name of the holy book on the 6.0?
  #47 (permalink)
Old 07-08-2007, 11:00 AM
brickie's Avatar
brickie brickie is online now
brickie has a very good reputation on FTE. brickie has a very good reputation on FTE. brickie has a very good reputation on FTE. brickie has a very good reputation on FTE.
Its in a link on the top of the list of topics on the 6.0 topics page.You passed it to get here.Take the link that has 6.0 Bible listed in blue I found it easy to find everything I needed there.As for the TSB info go here www.intellidog.com/dieselmann/60bulletin.htm Sorry I dont know how to post the links,Bricklayer ya know.
  #48 (permalink)
Old 07-08-2007, 11:06 AM
brickie's Avatar
The link posted!Anyone want to tell me how the link automaticly posted?Here is the other one I hope dan.prxy.org/Truck/6L_bible_html/html/TOC.html
  #49 (permalink)
Old 07-08-2007, 05:05 PM
blackhat620's Avatar
blackhat620 blackhat620 is offline
blackhat620 has a great reputation on FTE. blackhat620 has a great reputation on FTE. blackhat620 has a great reputation on FTE. blackhat620 has a great reputation on FTE. blackhat620 has a great reputation on FTE.
Quote:
brickie the reason this link didn't automatically become and active URL is because it is not preceded by "http or www"
You can force this to become an active URL by clicking on the "Insert Hyperlink" (picture of World & Chain) or including "http or www" when creating your post.
Also at the Top of the FTE forum are tabs, click on the one marked "Recalls/TSBs" to see all the TSB's
Hope this helps
__________________
Courage is being scared to death---and saddling up anyway.
-John Wayne-
06 F350 CC SB 6.0 4x4, Suburban Ford (Thanks Ernie )
04 F350 CC SB 6.0 4x4, Van Bortel Ford (Thanks Jeff ) [Traded 05/2006]
  #50 (permalink)
Old 10-02-2007, 06:55 PM
3000 FPS's Avatar
3000 FPS 3000 FPS is offline
3000 FPS is starting off with a positive reputation.
I thought that if you had a truck with the 6.0L built before 9/29/03 that there was a recall released in Feb 2006 that would do away with the information put out by the exaust back pressure sensor. the recall is 06E17. I thought that there was such a big problem with this sensor that even though they leave the sensor in place with the recall the information from it is ignored and inferred by the other sensors instead.
  #51 (permalink)
Old 10-02-2007, 09:35 PM
brickie's Avatar
Knock on wood .I dont require visits to Ford.I am way behind on flashes from the dealer!~My flash is old
  #52 (permalink)
Old 10-03-2007, 01:17 AM
3000 FPS's Avatar
Well you know what they say. If it ain't broke don't fix it.
  #53 (permalink)
Old 10-10-2007, 06:30 PM
Bustaduck Bustaduck is offline
Bustaduck is starting off with a positive reputation.
need help truck shutters are skips like a gas ing. under load or heavy accel. cleand egr didn't fix got any I DS
  #54 (permalink)
Old 04-20-2008, 06:14 PM
leadfootal leadfootal is offline
2004 Ford F-350
leadfootal is starting off with a positive reputation.
I thought that this is what the issue was on mine but the turbo caused the same issues.Also there has been an update on the sensor going into the valve cover so change it if you have not.
  #55 (permalink)
Old 04-20-2008, 07:25 PM
thanks for the reply
It's going to the shop next week maybe they want stick it in to deep
  #56 (permalink)
Old 04-20-2008, 08:12 PM
2004 Ford F-350
After you get it fixed make sure to run howies additive world of diff using this stuff in fuel and keeping egr clean.Have used all sorts this stuff works great.Keep us informed on what they found!
  #57 (permalink)
Old 04-20-2008, 09:15 PM
where do I get howies add.
  #58 (permalink)
Old 04-20-2008, 10:17 PM
jmaskew's Avatar
jmaskew jmaskew is online now
jmaskew is gaining momentum as a positive member of FTE. jmaskew is gaining momentum as a positive member of FTE.
Quote:
Here's a link to the site:
Howes Lubricator
__________________
^Camping at ZION NP, Utah^
Jonathan
2004 F250 PSD SB King Ranch 4x4:Build Date: 01/23/2004
Dieselsite Coolant Bypass Filter, High Idle Mod
Fumoto Oil Drain Valve, Harpoon Mod, Zoodad
Isspro 40 PSI Boost, Water Temp, Oil Temp and Trans Temp
  #59 (permalink)
Old 04-21-2008, 12:04 AM
cokecrazed007 cokecrazed007 is offline
cokecrazed007 is starting off with a positive reputation.
Is this sensor located under the coolant resavor, attached to a tubeinto the exhast manifold? If it is you should also clean out the tube, because it will get plugged off.
  #60 (permalink)
Old 05-03-2008, 02:02 PM
dstock dstock is offline
dstock is starting off with a positive reputation.
Engine Over Heat
05 F 350 6.0 D DRW Supercab, South AL,GA & FL
Three time last year I when towing up a grade I got a beep, engine over heat read out, before I could get stopped the Temp guage returned to normal, blew three qts of anti-freeze. Was in OEM Tow Mode, boast under 20, tow weight less than 8K.
Dealer of course cannot duplicate problem and could not find cause.
I do not remember hearing the Electric fan as I had in the past towing up much larger hills.
In the wiring diagrams up date I see there is an Elec Fan Control, engine mounted.
Is there a way to test the operation of the fan and control which I assume is
temperture activated ? with like a multimeter.
I did not get a DTC failure code.
Tags
2004 , 60 , 60l , altitude , bible , dieselmann , ebp , fix , ford , powerstroke , problems , sensor , stalls , symptoms , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
