Help with aftermarket keyless
I just installed aftermarket door lock actuators and a Crimestoppers 865 keyless entry.
Tesor door locks work fine. But if I hook up the keyless module, it pops fuses. Anyone with knowledge of hooking up aftermarket keyless entry with aftermarket door locks? Could use some help here.
Thanks Chris
Thanks Chris
Thanks Doug_j
Thanks Doug_J
I finally figured outthat it was the auto actuator conflicting with the remote. Thats pretty much what you are saying I think. Rather than add a relay to an already complicated system, I am going to remove the brown and white wires from the harness, and just use the actuaters as 2 wire ones, remove the autolock module. I figure that with the key on locking of the doors I can get by without the autolock.
I am adding power windows, cruise, power door locks, and remote. Between that and the election I think my mind is fried...
Thanks again Doug_J for what is undoubtably the problem.
Chris
Chris
