Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-02-2004, 09:13 PM
SlickRanger SlickRanger is offline
Garage is empty, add now
SlickRanger is starting off with a positive reputation.
Exclamation Loud Click at differnt rpms (idle)
my 2.5 makes a loud clicking sound when idleing. When it clicks the engine revs change. they either go from 1000 to a little less than 1000 or even sometimes all the way up to 1500. any thoughts??
SLickranger
  #2 (permalink)
Old 11-03-2004, 09:36 AM
hotrodfeguy hotrodfeguy is offline
hotrodfeguy is starting off with a positive reputation.
My guess would be
this sounds like one of two things.Either its a worn lifter/cam rocker or a rod bearing failure.It really depends on the sound it makes.The rod is lower inside the engine and makes more of a thud to the click.The lifter/cam rocker is high in the engine and make a higher clicking sound due to less mass.If I had to make a bet I would guess valve train noise.If its suspected as valve train pull valve cover off and let engine idle use a soft hammer handle(ie wood rubber)and push down on the lifter pivot this will tell you witch one it is and if it is the lifter itself.The sound should change on the bad one.Now if it is cam or rocker pry up on the same one(pivot may have to use a screw driver) and the noise should go away. Good luck.
__________________
64 FAIRLANE 428
67 F250 352 8 1/2 FT PLOW
Tags
clicking, engine, idle, loud
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
