Oil leaks on 97 f-250 diesel
Originally Posted by Hyside5
I just noticed some oil spots on the driveway. I noticed some build up on the turbo pipe. Most oil was on the oil pan/nearby parts. The local shop said that the main seal was going bad. This is bad. An thoughts would be appreciated.
Thanks, Rob
Thanks, Rob
could be your galley plugs at the back of the heads theres a big plug right at the back of the head they revised the oring in the pulgs old ones had two rings new ones have one big oring there like $15 a piece if thats whats leaking
if you got a little inspection mirror you can see the back of the head. theres a 1/2 round part of the head and there at the end of there. the ford part # on thoose plugs are #6026
a flex head type 1/2 rachet makes getting thoose things out and back in much easier
Turbo pipe
It is the "up" pipe, with the rubber gasket, looks like oil but only exhaust goes through that right? Also I went to the car wash to clean the underside and maybe locate the problem. I was told not to wash the motor from the top, should I or no?
Originally Posted by ltfox
"Turbo Pipe"........ are you talking about your turbo outlet(downpipe) or your exhaust manifold to turbo pipes(up pipes).
I agree that it is probably the galley plugs. I had a 1997 F350 that was leaking and I was finding it all over the motor. 3 of my 4 plugs were leaking and I intended to fix them but I decided to trade it in instead. Good thing I did to cuz I just saw it sitting behind the service center at the dealership about 2 weeks ago when I was getting my oil changed. I was really glad I didn't have to pay to repair it but it sure made me miss the old beast. I'm not so sure I did the right thing by trading it for a Ranger???? Oh well....hind site is 20/20
Rack Daddy
19
12-09-2011 05:46 PM
shark1979
27
07-18-2010 03:48 PM
6LPSD
10-02-2008 07:25 PM
