wiring up the gauges
with your tranny gauge you should also been sold a sending unit. (if you told them you had a superduty) it should screw into the inspection port on the drivers side of the tranny(once you take the plug out) it is towards the front of the pan on the side of the trans.(e4od or 4r100)
the boost can be tapped into the map sensor line. put your hand on the oil filler cap, move it straight to the passenger side of the engine compartment, you will hit the map sensor(black box with a wireing harness clipped to the front of it and a black, 3/8" hose comming out of the back of it) the hose that comes out of it goes into the intake manifold(under and in front of the turbo charger) tap the boost in to that hose
jasindude1
09-17-2014 06:37 PM
knucklehead11
Bronco II
09-12-2003 08:59 AM
