Desktop Dyno Please
Old 11-02-2004, 05:13 PM
umdstang's Avatar
umdstang
umdstang is offline
Desktop Dyno Please
Hi i was wondering if anyone could help me choose a cam with their desktop dyno.
I am trying to choose between these three cams, all mechanical flat tappet.
Comp Cams grind # FS 270S-10
Gross Valve Lift 0.499 0.499
Duration At 0.015 Tappet Lift 270 270
Duration At 0.05 224 224
Lobe Separation 110
Comp Cams Grind Number FS 282S-10
Gross Valve Lift 0.528 0.528
Duration At 0.015 Tappet Lift 282 282
Duration At 0.05 236 236
Lobe Separation 110
Isky rpm 300 part #381333
1 compr. RPM-Range
2000-6000 Valve Lift - INT
.476 EXT
.476 Valve Lash Hot - INT
.020 EXT
.020 ADV Duration - INT
270° EXT
270° .050 Duration - INT
228° EXT
228° Lobe Center
108
I have a 347 stroker with forged srp pistons 9.7 comp ratio
5.4in rods cast stroker crank
Ported stock heads with 58cc combustion chambers comp cams roller tip rockers
Offenhouser dual plane intake 600cfm edlebrock performer carb
Hooker super comp headers and flowmaster super 40 series mufflers
If you could please tell me the horsepwer and torque at rpms
It is goin in a 68 mustang with an automatic
Thanks
Brian
dimora
176
04-26-2018 08:00 PM
NIdude
04-14-2015 10:25 PM
ford5.8
15
10-09-2010 10:34 PM
Azguy54
08-18-2004 12:23 PM
jwtaylor
36
12-23-2003 09:15 AM
Quick Reply: Desktop Dyno Please
