gear ratio in Dana 20 and NP205
The cases are the same. With your claim of 31 splines and with a 2wd threaded portion on the output for the yoke, I figured that it was MD and something that I haven't ran across before. The output shaft in the picture looks larger, but I believe it is an illusion and it is the standard 2wd version.
If you used a standard Bronco NP435 adaptor and D20 spud gear, there is NO way that the transmission output was 31 spline. All early Broncos used 28 spline outputs on 3 speeds and automatics.
Jason
Jason
guess i should of had you look in here first. the last post
RANGER DAVE'S PLACE • View topic - The TRACTOR
I have to agree with RCrawler. Bronco dana 20's only had the one input spline count which can be found on the 2 wheel drive NP 435. When I built mine I didn't need to even cut off the threaded portion. If you wanna build a cheap adapter you can cut the bronco adapter off behind the 3 speed bolt pattern and cut the two wheel drive rear yoke flange off and weld the two pieces together if you get the right length. I bolted the bellhousing to the tranny and stood it on end on the bell housing and slid the t case on to line it up straight and tacked it together. Then we took it apart to weld it up solid. You need too find someone who can weld cast iron because it requires a special rod and process so it doesn't crack. But it can be done. I did it on my old bronco I had and it worked great never a problem and I drove it hard. Another buddy of mine has had his for years with no problems.
Ken2600
06-26-2014 03:45 PM
71hightoy
01-14-2010 03:15 AM
76 F-150 390FE
19
01-04-2006 09:25 PM
