1966 - 1977 Early Broncos
gear ratio in Dana 20 and NP205
Old 12-09-2008, 07:45 AM
tbolt 460's Avatar
tbolt 460
tbolt 460 is offline
31 spline 435
tag#
E17A7003 HA FE33
1I 1I 80 435
Old 03-22-2009, 07:55 PM
tbolt 460's Avatar
tbolt 460
Old 03-22-2009, 08:55 PM
RCrawler's Avatar
RCrawler
RCrawler is offline
That looks like a medium duty application 435. It looks like the case will work, but you need a 28 spline 2wd output shaft to use the typical Bronco D-20 adaptor.
Jason
Old 03-23-2009, 05:55 AM
tbolt 460's Avatar
tbolt 460
its all together isnt it??? how did i get the D20 on a 31 spline 435?? hello
Old 03-23-2009, 06:17 AM
tbolt 460's Avatar
tbolt 460
Jason
and just how do you tell what case is a medium or HD one???
Old 03-23-2009, 10:15 AM
RCrawler's Avatar
RCrawler
RCrawler is offline
The cases are the same. With your claim of 31 splines and with a 2wd threaded portion on the output for the yoke, I figured that it was MD and something that I haven't ran across before. The output shaft in the picture looks larger, but I believe it is an illusion and it is the standard 2wd version.
If you used a standard Bronco NP435 adaptor and D20 spud gear, there is NO way that the transmission output was 31 spline. All early Broncos used 28 spline outputs on 3 speeds and automatics.
Jason
Old 03-23-2009, 10:51 AM
tbolt 460's Avatar
tbolt 460
guess i should of had you look in here first. the last post
RANGER DAVE'S PLACE • View topic - The TRACTOR
Old 03-23-2009, 10:55 PM
RCrawler's Avatar
RCrawler
RCrawler is offline
I don't know what you're trying to prove, the existence of a 31 spline 2wd transmission or that you were somehow able to mate a 31 spline male shaft to a 28 spline coupler
Jason
Old 03-24-2009, 12:26 AM
hpheltersnach's Avatar
hpheltersnach
hpheltersnach is offline
I have to agree with RCrawler. Bronco dana 20's only had the one input spline count which can be found on the 2 wheel drive NP 435. When I built mine I didn't need to even cut off the threaded portion. If you wanna build a cheap adapter you can cut the bronco adapter off behind the 3 speed bolt pattern and cut the two wheel drive rear yoke flange off and weld the two pieces together if you get the right length. I bolted the bellhousing to the tranny and stood it on end on the bell housing and slid the t case on to line it up straight and tacked it together. Then we took it apart to weld it up solid. You need too find someone who can weld cast iron because it requires a special rod and process so it doesn't crack. But it can be done. I did it on my old bronco I had and it worked great never a problem and I drove it hard. Another buddy of mine has had his for years with no problems.
Old 04-07-2009, 02:30 PM
Rulebreaker's Avatar
Rulebreaker
Rulebreaker is offline
An NP 435 out of a 4x4 with the divorced 205 will also work as that is what I have in mine. I used the 6 cylinder intermediate piece and built my own adapter. I had like $50 into it plus like $60 for the 6 cylinder piece, but that's been 5 or more years ago. RB
apachetech
12-30-2014 03:04 PM
Ken2600
06-26-2014 03:45 PM
71hightoy
01-14-2010 03:15 AM
76 F-150 390FE
19
01-04-2006 09:25 PM
Goodold71
Offroad & 4x4
11-28-2002 03:36 PM
Quick Reply: gear ratio in Dana 20 and NP205
