gas mileage 89 7.3 vs dodge 360 5.9 - Ford Truck Enthusiasts Forums
Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
Old 11-01-2004, 11:37 PM
Fordfreak1978 Fordfreak1978 is offline
Fordfreak1978 is starting off with a positive reputation.
Which of the two trucks would get better gas milage an 89 7.3 or a 95 dodge ram 360 5.9l gaser, supposing they both are stock. Or what if the 89 had the 7.3 banks power
Old 11-01-2004, 11:50 PM
johnsdiesel's Avatar
johnsdiesel johnsdiesel is offline
johnsdiesel is starting off with a positive reputation.
The 7.3 IDI will get better mileage. When I first saw 5.9 I assumed you were talking about a Cummins.
Old 11-01-2004, 11:55 PM
hey thanks alot
Old 11-01-2004, 11:58 PM
BigDaddy6969 BigDaddy6969 is offline
BigDaddy6969 is starting off with a positive reputation.
7.3 IDI=Not real good mileage
5.9 Gasser= worse mileage
Personally i am not real big on the IDI motors.
Old 11-02-2004, 05:57 AM
351M's Avatar
351M 351M is offline
351M is starting off with a positive reputation.
Well, I can tell you that the IDI will do better. Diesel is almost as much as Gas now, We have a Fullsize Dodge 15 pass. Van 5.9, 3.9 gears, 4 spd auto. My old man towed a loaded U-haul trailer to Manitoba, and figured the milage out to around 19 Mpg. (that was there and back not one way) The old '88 diesel we have supercab 1-ton dually 4:10 Limited slip, 2wd, C6 6.9 still runs every day for alot less then the van will and it gets about 15Mpg, go figure eh?
Old 11-02-2004, 09:21 AM
Big_Al59 Big_Al59 is offline
Big_Al59 is starting off with a positive reputation.
I had a 88 dodge 3/4 ton 4wd with a 360 4bbl, 4:10 gears and averaged around 12 mpg, I average 17 mpg with my 97 psd f250 4wd 4:10 gears.
Old 11-02-2004, 11:33 AM
Frost13's Avatar
Frost13 Frost13 is offline
Frost13 is starting off with a positive reputation.
the 360 will get horrible mileage
the 7.3 should get pretty good mileage
Old 11-02-2004, 11:35 AM
Frost13's Avatar
the 7.3 should get even better mileage after the banks stuff
7.3 L ford vs 5.9L dodge jadel 1999 - 2003 7.3L Power Stroke Diesel 38 02-01-2017 11:37 AM
Well boys and girls. I traded Er in. DanielT28 1999 - 2003 7.3L Power Stroke Diesel 14 06-15-2016 01:35 AM
Why did you buy your truck? johnwassink 1999 - 2003 7.3L Power Stroke Diesel 20 09-05-2014 12:02 AM
Just bought a 2003 7.3 F25 and have questions true blue 1999 - 2003 7.3L Power Stroke Diesel 18 12-18-2010 12:04 AM
5.9L V8 vs 5.4L V8 LPD111 Ford vs The Competition 40 12-08-2003 11:46 AM
Tags
360, 59, 73, 89, diesel, dodge, expected, ford, gas, get, idi, litre, milage, mileage, mpg
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
