4.6L worth??
You will have to run at least 93 octane fuel with the higher compression. @ well over $2.00 a gallon, that would be aweful costly for a daily driver.
The head/cam swap to PI heads is worth about 35hp. That put the 99GT up to about 260hp. The DOHC Supercharged 03 Cobra only has 390hp so I would think that the engine that you are looking at is probably in the 280-290hp range.
