How do you remove a broken easy out?? - Ford Truck Enthusiasts Forums
Old 11-01-2004, 01:35 AM
hrdrckgld hrdrckgld is offline
hrdrckgld is starting off with a positive reputation.
Angry How do you remove a broken easy out??
My step son has a mildly built up 302 in his 73 Bronco. The oil presure sender located low on the front of the block near the fuel pump broke off. He used an "easy out" type of tool to try to remove it and it broke off! I have a feeling it was an imported tool, not the real thing, made in the USA. Anyway what is the next step?? He is thinking of having to take out the engine and scrap the block, but there has to be a better way. Any sugestions?? He is a very competant mechanic, has built several engines and has his own Mobile Mechanic buisness that is very successful. Any help would be very much appreciated!
Harry
Old 11-01-2004, 07:11 AM
fordman300 fordman300 is offline
fordman300 is starting off with a positive reputation.
if you take a center punch and beat on it it will shatter because it is so hard. the only problem with that is all the little pieces will end up in the oil and thyrougout the mottor. i do this all the time with taps that get broke off if a hole.
Old 11-03-2004, 12:39 PM
daerhldgs2 daerhldgs2 is offline
daerhldgs2 is starting off with a positive reputation.
the last post is probably the best way , but you might try a carbide bit, it may drill it but most likely would chip the bit because of the uneveness of the easy out.
Old 11-04-2004, 10:16 AM
Smile
Thanks for the responses, a check of the engine and oil filter shows metal pieces, so he is going to send a spare block to the machine shop and rebuild it with some of this engines parts (only has about 10,000 miles on it) and new rings and bearings. Thanks again.
Old 08-12-2014, 10:46 AM
lm987 lm987 is offline
lm987 is gaining momentum as a positive member of FTE.
Easy -out removal
I have the exact same problem. Does any one know of an alternate location for the oil pressure sender location???
Thanks
Old 08-14-2014, 11:49 PM
Beanscoot Beanscoot is offline
Beanscoot is gaining momentum as a positive member of FTE.Beanscoot is gaining momentum as a positive member of FTE.
Not so easy-out
I have removed them by very careful use of an oxy-acetylene torch. I even got a 1/4" bolt with broken tool inside removed. Since your situation will be 1/4 NPT, there will be lots of room for working.
Even good US made "Easy" outs (the world's most ironically named tool) will break. If the screwed piece broke off when it was unscrewed, then it is extremely unlikely an easy out will then take it out.
BATTERY MAINTENANCE ? What you say! Thomas White 1999 - 2003 7.3L Power Stroke Diesel 4 07-11-2015 02:25 PM
2011 F350/Issues..Turbo/Smells/Shutter/Death Wobble/Transmission/…with VIDEO!! Big-Sarge 6.7L Power Stroke Diesel 45 06-19-2015 01:06 AM
Dual Battery Disconnect bismic 6.0L Power Stroke Diesel 8 04-09-2015 01:47 AM
My Pace Edwards “Switchblade” Review/Install gaselectjoe 2009 - 2014 F150 5 03-03-2014 05:55 AM
2004 F250 6.0 Rough Idle, Loses Power When Hot ten.mile 6.0L Power Stroke Diesel 3 12-12-2012 02:47 PM
Tags
broken, easy, engine, ez, f250, mississippi, removal, remove
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
