After market granny tranny shifter
Old 10-31-2004, 08:42 PM
tastyklair's Avatar
tastyklair
tastyklair is offline
I have a 73 f100, 4wd, 390, 4spd with the granny gear. Are there any alternatives to the stock shifter?
Old 11-01-2004, 08:20 AM
73Custom's Avatar
73Custom
73Custom is offline
Not that I know of - most of the aftermarket shifter ***** will fit, but that retains the stock shifter. I used a piece of foam pipe insulation for 1/2" copper pipe and slid it over the shifter rod, it helps to dapen the sounds of the tranny (they vibrate through the shifter) and feels/looks better.
Marty
Old 11-01-2004, 07:52 PM
proeliator's Avatar
proeliator
proeliator is offline
One does not exist, as your shifter is integral with the transmission. You CAN heat and re-bend the shifter for better angles if you wish, or even cut and shorten it.
Old 11-01-2004, 09:07 PM
thelonerangerxlt's Avatar
thelonerangerxlt
thelonerangerxlt is offline
Very interesting. I used a section of heater hose on mine. Apparently this is an old OTR trucker's trick.
The shifter rattle/vibration is really bad under some conditions. I've tried everything to get rid of it, with no success..........
Old 11-02-2004, 08:25 AM
73Custom's Avatar
73Custom
73Custom is offline
I notice no rattling/vibes with the foam insulation. Try some, it's cheap and available at any home store or lumber yard.
Marty
Old 11-02-2004, 08:58 AM
raptor660rr's Avatar
raptor660rr
raptor660rr is offline
I posted the same type of question in the "tranny" forum for an NP435 but had no replies.
So as of right now there is nothing in the aftermarket the could replace a stock NP435 shifter?
Old 11-02-2004, 09:40 PM
proeliator's Avatar
proeliator
Like I said...
timmyboy76
08-01-2016 09:50 PM
HMB_Superduty
07-27-2015 01:10 PM
my-ford
12-05-2014 10:03 PM
80ford100
11-29-2014 09:52 PM
mustange70
Offroad & 4x4
08-13-2006 12:31 AM
Quick Reply: After market granny tranny shifter
