Duramax, Cummins or PSD - Who is the most powerful?
#31
You never heard of a short stroke inline?
They have better balance thus less weighting of the crankshaft. Its cause and effect. Less reciprocating mass equals higher possible rpms. The cummins has a much longer stroke but can still outspin a PSD. Stroke is a major factor but so is the weight of the crank. The cummins connecting rods and pistons are extremely heavy but will still put up with higher rpms. Perhaps due to less stretching of the conrod.
#32
LH, sorry I have built to many big stroke and short stroke performance engines. The crank is zero balanced regardless of weight. It all comes down to stroke length. The only reason the cummins can spin higher is because of the strength of the components. Give me better rods I will spin the V8 much higher than you can build the I6.
#33
I dont know why a person would put a diesel in an old goldie but to every one his own i guess. Personally i think diesels are to expensive to buy and mod out. Why mod a new truck when in a year or two they will be putting out the power you want when they are sold stock, especially the way this war is going now. I just wish gas was down to about a dollar a gallon then i would have nothing but 428's/429's/455's/427's/440's/454's/460's in every old vehicle i own. Wow wouldnt that be nice!
#34
BigDaddy, I know people with 1994-1997 PSDs putting out over 1000 ft/lbs of torque. All in all, the amount of money it takes to mod a diesel is much less than a gas engine. There is a lot more potential in a diesel. You can also run a heavily modded diesel on regular diesel fuel, but you can't run a highly modded gas engine on good 'ol 87 octane gasoline.
#35
#36
Originally Posted by Logical Heritic
Could you not do the same for the cummins? Shorten the stroke a smidge and bump up the rpms with lighter stronger rods and a lighter piston. Just thinking of the flip side of the coin. I like to think of both sides of the argument.
With the curent blocks as a base and aftermarket support the V8's will out spin the Cummins. More rpm's means faster speeds. It's and easy equations.
#37
But the 56 will be a dirve to event show truck and it will have to pull a 22ft airstream behind it. Problem is with a gas motor it is very hard to build perfomance and the ability to tow in one package. Not so with diesel. Sure it may cost more but then again I will also get more power and still be able to tow. In fact it will run dualies when towing and street slicks for show.
#38
#39
I must say that it does come down to personal preference. Wether you want a smooth riding quiet diesel (Chevy) or a decent truck with a lot of grunt and torque (Dodge) or a great truck with a good engine for pullin and gettin around (Ford). It's all a matter of choice.
On the engines, it is a well known fact that a long stroke will give you a lot of oomph. That is why the Cummins has a lot of low end power.
Actually since 89. 94 was when Dodge came out with the new body style and they advertised the Cummins a bit more. The diesel sales for Dodge in 94 were a lot higher than they were in the previous years.
Yes, the Cummins pistons and connecting rod are heavy and quite large. Plus a crankshaft that wieghs in around 175 lbs. The Cummins 5.9 is limited in its RPMs. The 12 valve redline was 3000 RPM, the 24 valve is at 3200 RPM. This is not countin the guys that heavily modify the engine to achieve higher RPMs and power.
Just found this on the web too. A side by side comparison on the internals of a Duramax, 6.0 Power Stroke, and the 5.9 Cummins.
The cummins has been around since 94 I think.
#40
Interesting pic there. Yah the connecting rods are heavier on the Dodge Cummins no surprise there. 6 rods have to do the work and carry the load. Where as Ford and Chevy have eight to do the same work. So all in all no advantage there. The 6.0 is a good combination off power and torque and off course its in the best truck Ford so why have anything else. Theres nothing faster then a 6.0 on the road today. If your in to drag racing (diesel style) 6.0 is King no ifs and buts about it.
#41
150Ford
You obviously aren't looking around. There are a number of dodges and one ford(w/cummins) that are in the ten second range. None in fords unless I am mistaken. The fastest psd ford that I have heard of is the 11.78 from David Lott.
#43
#44
#45
